Cutting Base Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 11:48 AM   #1
I have an outside corner that is less than 90 degrees. How do I cut the angles. The corner is 80 degrees so I need to cut at 5o degrees. The miter saw only goes up to 45.
lnot is offline   Reply With Quote
Old 03-21-2010, 02:43 PM   #2
DIY staff
Rewards Points: 7,174
You said 80 ? isn't half of 80=40 degrees ?
Old 03-21-2010, 09:50 PM   #3
Rewards Points: 506
Maybe make up a miter box?
One-half of 80 is 40, but you have to cut the miter at the complementary angle of 90 degrees, because the miter cut is made perpindicular to the the plane of the desired angle. Thus, 90 minus 40 = 50...the degrees to cut the miter.
jlmran is offline   Reply With Quote
Old 03-21-2010, 11:10 PM   #4
DIY staff
What? .
Old 03-21-2010, 11:28 PM   #5
So you can't make that cut on a saw that only goes up to 45 degrees.
Old 03-22-2010, 07:27 AM   #6
DIY staff
You will have to block the fence out so your base sits 5 degrees out---
I still am confused about the explanation--But there are some things that I never do understand,--Mike--
Try this--make a paper template and fold it in half--This will give you the angle.
For an out side corner simply lay two sheets of paper on top of each other to give you a paper "corner"--Tape them together--
Fold the template in half--This is the miter angle.
Set the saw at 45--slide the template against the blade--see how far off the fence that the back edge of the paper sits---
cut a spacer scrap the width of the gap between the paper and the fence and tape the spacer to the fence.
There you go now the saw will cut more than 45.--Mike--
This paper template can be used on inside corners too.
Fold a single sheet of paper to match the corner --fold it in half and put the template against the saw fence--set the blade to the paper and you're done.
We need Willie-T's magic pencil--I must take the time to learn more about computer sketching----
Dave88LX (10-24-2013)
Old 03-22-2010, 09:50 AM   #7
Rewards Points: 506
Miter versus bevel. We need to make certain we're talking about the same thing.
How are you cutting the board? Flat, or on edge?
Old 03-24-2010, 02:47 PM   #8
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
CAD illustration attached:
If your outside corner is 80*, you cut each board at 40*. You have to cut each board at the same angle, or they will not meet up flush.
hyunelan2 is offline   Reply With Quote
The Following User Says Thank You to hyunelan2 For This Useful Post:
oh'mike (03-24-2010)
Old 03-24-2010, 09:53 PM   #9
firehawkmph's Avatar
Rewards Points: 1,922
Hyu,
That's not the proper orientation for the 80 degrees when referencing a 90 degree corner. The 90 degree corner is opposite of what you are showing. Picture this corner if it were a 45 degree corner, the two walls meeting would form an obtuse angle, not an acute angle like you show in your drawing. This argument comes up from time to time when someone new on a miter saw doesn't understand the orientation of the blade to the fence and doesn't divide the actual angle in half. I hope this makes some sense.....
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-24-2010, 11:51 PM   #10
you are wrong!
Originally Posted by firehawkmph View Post
Hyu,
Mike Hawkins
you are RIGHT!
Brad Talent is offline   Reply With Quote
Old 03-25-2010, 09:13 AM   #11
hyunelan2's Avatar
Rewards Points: 692
So when you say it's an 80* outside corner, this is what it means?
(CAD image attached)
Old 03-25-2010, 04:26 PM   #12
Yes,
that is more like it. I wasn't sure if I explained it well. Just keep in mind the angle refers to the side of the wall that you are trimming. Then the angle is in reference to a perpedicular line off the wall (90 degrees in a perfect world). In your drawing the wall is just under 90 degrees, so the 80 degree reference makes sense. Then the angle gets divided in half when transferred over to the miter saw. Think of how the miter saw is designed. The saw itself when placed in the 0 degree position is perpendicular to the fence, hence 90 degrees. The fence reprasents the wall at 180 degrees. The saw bisects the fence, which is why we cut our angle in half. Does that make sense? I know it gets confusing when reading. The best thing is to go over to the saw and make a few cuts in scrap pieces and see how it all works.
Mike Hawkins
Tags
cutting , molding , outside corner
Cutting bullnose crown molding... jaysen Carpentry 1 09-22-2009 12:12 PM
cutting cove molding Bluwolf Remodeling 2 09-11-2009 07:39 AM
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 09:28 PM
base molding and carpet doc70 Flooring 2 04-09-2008 11:33 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
