Cutting Base Around 3/4" Corner Bead - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 01:40 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Cutting base around 3/4" corner bead
I've seen carpenters doing this with 2/4/6 small pieces of baseboard to make a transition around the corner. I'd be ok just using 1 or two pieces but I can't wrap my brain around how to figure the length of the pieces needed when doing this.
Journeyman Plumber
Old 02-27-2010, 02:46 PM   #2
Rewards Points: 5,336
Post is a little vague. Are you trying to wrap a base molding around a 3/4" radius?
Ron
Old 02-27-2010, 03:32 PM   #3
Old School
Willie T's Avatar
If you feel you must try to use math on this, here is the 'theoretical' dimension across the inside bottom for a 3/4 radius. But it never works out exactly right.
Most guys will slide both pieces till they get what looks good to them, and mark the floor. 5/8" to 3/4" usually comes out close. Sometimes you need 7/8".
Cutting base around 3/4" corner bead-3-4-radius.jpg
Willie T
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 04:25 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 09:20 AM
