Cutting base around 3/4" corner bead
2K views 2 replies 3 participants last post by  Willie T
I've seen carpenters doing this with 2/4/6 small pieces of baseboard to make a transition around the corner. I'd be ok just using 1 or two pieces but I can't wrap my brain around how to figure the length of the pieces needed when doing this.
:huh::whistling2:
#3 · (Edited)
If you feel you must try to use math on this, here is the 'theoretical' dimension across the inside bottom for a 3/4 radius. But it never works out exactly right.
Most guys will slide both pieces till they get what looks good to them, and mark the floor. 5/8" to 3/4" usually comes out close. Sometimes you need 7/8".
