Cutting At An Angle Against The Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 07:29 PM   #1
cutting at an angle against the ceiling
looking for tips or tricks to finish this up.
i'm putting cedar fence pickets that have been cut and stained on the wall.
the first picture shows what i did on the first inset. the second shows what i'm dealing with. this inset has the angled ceiling. is there an easy way to mark the angle correctly for the boards that will butt up against the ceiling?
any help would be great appreciated, i'm a little stumped.
thanks a ton in advance,
jon
cutting at an angle against the ceiling-photo-1.jpg   cutting at an angle against the ceiling-photo-2.jpg   cutting at an angle against the ceiling-photo.jpg
jon71203 is offline   Reply With Quote
Old 01-31-2013, 07:30 PM   #2
sorry, photos are out of order compared to what i originally typed, but you'll get the idea
Old 01-31-2013, 08:40 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
i dont understand what your talking about from the picture, is it for horizontal boards or are you installing vertical boards in the gable section
woodworkbykirk is offline   Reply With Quote
Old 02-01-2013, 08:19 AM   #4
this is for putting the boards in horizontally.
Old 02-01-2013, 08:33 AM   #5
Rewards Points: 1,294
Lets see if I can explain this without drawing it out.
First, take a scrap board and tack it to the wall, level or plumb, near the cieling that you need to make the cut fit. Next, hold a board against the ceiling and over the board you tacked to the wall.
Now, use a pencil and scribe a line on the tacked up board using the other board as a straight edge. This will transfer the angle of the ceiling to the wall board.
Take down the board that you tacked up and cut along the line. This will give you a template to use to scribe and cut the other boards you want to put up
danpik is offline   Reply With Quote
Old 02-01-2013, 08:45 AM   #6
this is what i was looking for. thanks danpik.
the scrap board that i tack up, does it matter where as long as i get the angle as a template?
Old 02-01-2013, 09:00 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
once you have the angle all other boards will be the same angle and you just pull measurements to the long point of the angle or the short point. you can even figure out what the measurements are for the next piece above from measuring the previous piece below.
another way is to draw the piece/pieces out on the wall and then measure to what you have drawn and then cut to your measurement. be sure and nail the boards to the wall studs...
when you get to the point where the roof angles meet just plumb down from the tip of the point and mark the board on the wall with your aligned ceiling point plumb mark, that will show you where the point is located from side to side and you just need to measure vertically to get those numbers
hand drive is offline   Reply With Quote
Cutting a 6" hole in wood lath plaster ceiling dwoloz Drywall & Plaster 1 09-22-2010 08:07 PM
Cutting roof sheathing at an angle (plumb) cellophane Building & Construction 9 04-03-2010 10:10 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
ceiling fan support triplnikl Carpentry 5 03-06-2009 03:47 PM
