Cutting Aluminum Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2006, 07:06 PM   #1
Cutting Aluminum siding
I need to cut a circular hole ( approx. 2 inches in diameter) in existing aluminum siding and want it to be neat without tearing it .How do I cut this hole,quickly and surely ?
gmjosey is offline   Reply With Quote
Old 08-22-2006, 11:45 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a hole saw (bit) attached to a corded variable speed drill. A hole saw bit is circular, like an empty tin can. Use one with metal style cutting edges. Look in the Drill bit department at your local hardware supplier.
Don't start off going full speed with the drill, try it at about 1/2 - 3/4 speed and adjust it up, once you get the circular cut started...
Good Luck!
- Build Well -
Old 08-26-2006, 05:41 AM   #3
Good Luck!
Thanks. Starting off ,slowly,is a good reminder for me !!
Old 12-16-2006, 11:55 AM   #4
Better late than never, and hopefully will help someone else searching....
I like to do as noted above but I simply start the drill bit (slowly as mentioned) to make the pilot hole, then I run the drill/holesaw in reverse to get an accurit start on the actual hole (this will start your trench without skipping around damaging the surrounding soffit or siding).
Again, take your time and watch your drill speed. Once the groove is deep enough (and if your not able to complete the cut in reverse) return your drill to forward and gently finish the hole.
-Greg
smokumchevy is offline   Reply With Quote
Aluminum siding miami vice 25 Building & Construction 2 05-22-2007 04:13 PM
Aluminum Siding in Contact electric1 Electrical 1 03-31-2005 08:48 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
