Cutting A 63 Degree Angle On A 2x8 With A Circular Saw - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 07:37 AM   #31
Joe,
Thanks for your post here, very helpful. Once the footings are completed I will be framing a irregular/bastard overhang on my patio. It will actually be half a hip roof, not sure what that is called. Anyway the sides will be a 6 pitch and the front will be a 3 pitch. I have it drawn up in CAD and was trying to figure out how to cut the ~67 degree angle where the rafters meet the hip rafter on the 3 pitch. Anyway I know it is slightly off topic but I was wondering if you had any experience with bastard hip roofs. Looking for some guidance on figuring out the hip rafter length. I can get all the other lengths from the cad drawing in 2D, I am not a CAD expert in 3D.
-Mike
mmash is offline   Reply With Quote
Old 04-11-2013, 09:55 AM   #32
Rewards Points: 150
Originally Posted by Joe Carola View Post
It's a simple easy cut to make. Your making a big deal over nothing. That's why you consider it whacko. Anyone can make this simple cut.
Joe, so simple. Have to admit my first thoughts were how to miter it via tilting the blade and cutting on the flat side... but turning the board sideways will get you 2.5" into it on both sides, leaving only an inch or so to finish off w your reciprocating saw. Easy, stable, nothing difficult at all doing it that way. Nice.
SquishyBall is offline   Reply With Quote
Can't find instr. on cutting 135 degree inside angle in crown molding Hossenfeffer Carpentry 8 05-27-2010 08:25 PM
Cutting roof sheathing at an angle (plumb) cellophane Building & Construction 9 04-03-2010 11:10 PM
cutting plywood panels w circular saw Klawman Carpentry 11 12-11-2009 02:40 PM
how do you make a 90 degree angle on a fence sherrybjjay Building & Construction 7 05-02-2009 08:50 PM
How to Attach Two Beams at 45 Degree Angle on top of 4x4 Post? Ler0y Jenkins General DIY Discussions 21 07-18-2008 08:48 AM
