Cut Ends Of Barn Board - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 03:22 PM   #1
Question
Cut Ends of Barn Board
Hello all,
I've just purchased some very nice barn board that I intend to turn into a coffee table. Does anyone have advice on how to treat the cut ends in terms of having the color difference not be so noticeable?
That is, the exposed cut ends will no longer match the silvery grey parts of the wood that weathered over the years. I want to reduce that effect.
Thanks in advance!
Dan
DanFromOhio is offline   Reply With Quote
Old 03-29-2009, 05:41 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
end grain will almost always be different you could use a miter returned bread board edge
Tom Struble is offline   Reply With Quote
Old 03-29-2009, 05:58 PM   #3
the Musigician
DangerMouse's Avatar
breadboard edges would be best if it's one solid piece, but if it's more it'd be hard to do......
but maybe you could burn the edges with a torch and then wire brush them lightly and then clearcoat.
or you could use some grey primer and then when it's dry, maybe rub some ashes into the edges to blend the paint effect, then clear coat with satin finish. i did similar to repair a broken clock.
just a couple more ideas.
DM
Old 03-30-2009, 02:06 PM   #4
You could give these a try:
http://miniatures.about.com/od/minia...inegarwood.htm
http://www.xrestore.com/Pages/Aging.htm
Rivethead is offline   Reply With Quote
Old 03-30-2009, 09:52 PM   #5
Thank you guys for the responses, I appreciate the ideas. I'll let you know what works. I was even thinking of watercolor paint before sealing?
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 08:43 PM
Hide deck board ends bardad1022 Carpentry 4 06-08-2007 09:55 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
