Customizing A Pre-hung Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 11:57 AM   #1
Customizing a pre-hung door
I have a standard pre-hung door that I want to cut down to fit a doorway in an older house. The door is wood-cored vinyl, and I estimate that I will have to narrow it by about 1 1/2 inches. How difficult is this, and what is the best way to cut the door?
Martin1 is offline   Reply With Quote
Old 11-16-2009, 12:07 PM   #2
Framing Contractor
If you have to cut it down 1-1/2", why don't you just buy a 2" smaller prehung door?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-16-2009, 12:13 PM   #3
joe is right. Cutting down a vinyl skinned door on the vertical is a pain in the wahzoo especialy since you should cut both edges to keep it uniform
Old 11-17-2009, 08:18 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
The best way is on a table saw. Obviously, you should take 3/4" off each side. What we don't know is if the door has been predrilled for a lockset, meaning everything would need to come off of the hinge edge. You also need to be sure that the hinge and latch stiles inside the door are thick enough to allow you to remove that much material. Cut them too thin and you won't be able to recess the latch or the hinges.
Old 11-17-2009, 08:44 AM   #5
Hi,
Thanks for the replies. The door is pre-drilled for a lock set, so everything would have to come off the hinge side.
I would by happy to buy a smaller door, but I am trying fit it into a brick opening that is 33 1/2" wide. By the time I have built a frame the gap will be too small for a 32" pre-hung door and I haven't found anywhere that sells a 30". For another similar door we had to have one custom made which was expensive.
Old 11-17-2009, 09:03 AM   #6
Old School
Willie T's Avatar
Hi,
Pardon me, but you are talking about one of the most common door sizes in existence. Try another dealer.
Willie T
Old 12-26-2009, 01:57 AM   #7
YES , DO NOT CUT IT. JUST GET THE NEXT SIZE DOWN. PLEASE!!!!!
carpenter377 is offline   Reply With Quote
Old 12-26-2009, 09:13 AM   #8
Rewards Points: 5,336
If you cut this door as described, you might as well just bring it out to the curb for garbage pick up.
An exterior 30" door can be gotten for a reasonable price. Of course if you bought the wrong door the first time and cannot return it, it will more then double your total cost.
Better to ask pertinient questions before purchases.
Ron
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
adjusting metal pre hung garden door moisheh Carpentry 1 09-15-2009 10:00 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Pre Hung Door Issue! bmster Carpentry 8 03-11-2008 07:31 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
