Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-29-2010, 02:51 PM   #1
Customized kitchen island
I'm having a small moveable customized kitchen island made. The countertop slab I'm getting comes in 27" width, so with a 12" overhang for seating, the width of the island will be 15".
But since the island will be on wheels, the overhang is going to be too heavy for it and will tip over. Other than putting bricks/metal/etc. on the inside at the bottom of the island (which defeats the purpose of it being moveable) here are two ideas. Any other suggestions to not have it tip over but still able to move around?
hgtv is offline   Reply With Quote
Old 10-01-2010, 12:29 PM   #2
Stuck in the 70's
Blondesense's Avatar
Not an expert here, but I think any sort of stone/granite/slab top on a 15" wide rolling base would be prone to tipping, even without an overhang.
How tall is this going to be?
Even 27" wide may be tippy. If you want it tall enough for bar stools, dangerously so as people sitting may tend to lean on it or push against it.
Also consider your flooring. The weight of this slab will cause the rollers to leave dents in any sort of "soft" flooring. It will be even more prone to tipping if you have tile with grout lines or any sort of rough flooring the rollers may catch on.
Personally I would not put a slab on anything movable that is taller than it is wide.
I would look at other, lighter-weight counter top alternatives.
Old 10-02-2010, 04:29 PM   #3
I work in a countertop/cabinet business and I think both the pictures look like they could work. If it is supported and balanced correctly it won't tip over. I have some questions though. What kind of countertop are we talking about and what are the overall dimensions? Also what kind of floor is it going to be on? Blondsense is right about damaging the floor. I see it all the time where appliances are even the ones with casters. Mostly linoluem and hardwood is where I see a lot of damage from casters.
dukeofsolidsrfc is offline   Reply With Quote
Old 10-07-2010, 12:34 AM   #4
bigger wheels to spread out the weight distribution will reduce the chance of damage. but the above posters pointed out very good points. Heavy weight countertop sounds like recipe for disaster.
acerunner is offline   Reply With Quote
Two-levelled kitchen island with breakfast nook laughingduck Kitchen & Bath Remodeling 7 02-10-2010 12:03 PM
Kitchen island help Bob Sacamano Kitchen & Bath Remodeling 3 12-16-2008 06:38 PM
2-tier Kitchen Island ncoppola09 Carpentry 25 02-06-2008 05:37 PM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 08:37 PM
