Custom Window, Bend Or Cut The Curved Pieces? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 07:20 PM   #1
Rewards Points: 20
Custom window, bend or cut the curved pieces?
I am working on replacing rotten pieces of my custom framed front window. It is turning out to basically be a piece by piece rebuild and I am particularly stuck on the curved pieces.
I initially tried using an accuscribe to scribe the curve of the window on to a piece of 1x4 then cut it out with a jigsaw. This does work but looks bad, the cut is not consistent all the way through and I have to patch 2 ft pieces together at a time since I can't really accurately scribe anything larger.
I can probably trace out the glass that I remove onto a piece of 1x4 and cut that but again I'll be stitching many pieces together.
I was thinking about building a wood steaming jig and steaming the cut pieces to the point where I can bend them into shape and finish nail them in place. I am basically just ripping a 1x4 down to 1.5" pieces that are used to sandwich the window in place so I would only need to steam fairly small, but long pieces.
I have never steamed wood before so I'm not sure how well it will bend or if nailing it in place when it is still hot will even be an option. I am using treated pine.
picture attached.
Thanks!!
Custom window, bend or cut the curved pieces?-303628_506128126264_324300020_38379_1587902409_n.jpg
SteveB87 is offline   Reply With Quote
Old 06-04-2012, 07:26 PM   #2
Rewards Points: 12,808
There is no way to steam and bend wood in that direction.
Concider buying a sheet of 3/4, 4 X 8' PVC. it can be spliced with bisket joints and PVC glue.
It can be sanded, cut and painted just like wood but will not rot.
Old 06-04-2012, 08:27 PM   #3
Rewards Points: 20
I am not familiar with working with PVC. Would I be able to heat and bend it to shape so I can avoid cutting the proper and smooth curve? Would I be able to rip it to the correct width and finish nail it in place just like the wood I am using?
In addition to having trouble tracing the correct curve I also have trouble cutting it smoothly with the jigsaw. Would I be better off cutting the curve smoothly with a scroll saw?
Old 06-04-2012, 08:29 PM   #4
DIY staff
Rewards Points: 7,174
If Azeks pvc trim will work--that can be heated with a heating blanket and bent very easily--
Do you have a good shot of the piece you need to duplicate?
Old 06-04-2012, 08:34 PM   #5
Rewards Points: 20
I dont really have a good shot of the pieces that need to be duplicated as the window is so rotten it is basically just falling apart as I remove it. But I basically just need to produce a piece of 1.5" trim that can be butted up against the window on either side to hold the glass in place along the far left curved edge against the brick. I can easily finish nail the wood or other material into the plywood pieces that are attached to the brick.
Old 06-04-2012, 08:34 PM   #6
I'm messing up, are you just trying to form the inside of that arch?
I was thinking you were trying to form around the face.
What threw me off was your trying to use a Jig saw.
Old 06-04-2012, 08:37 PM   #7
recently retired
Rewards Points: 280
It looks like a simple lancet arch. You can make it with a router and a trammel jig.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
oh'mike (06-04-2012)
Old 06-04-2012, 08:52 PM   #8
Rewards Points: 20
I'm trying to form the piece that butts up against the brick and the glass.
I've attached another picture with a red line showing where I'm trying to build a piece. As you can see I've started on the bottom but I'm not too happy with the way its turning out.
I'm hoping you'll tell me you misunderstood my question and I can steam bend the wood in that corner?
Old 06-04-2012, 08:54 PM   #9
Rewards Points: 20
It is not quite a lancet arch, it does not have the pointed top. I believe it is closer to a parabolic arch.
Old 06-04-2012, 09:01 PM   #10
recently retired
Rewards Points: 280
I'd like to see a pic of the whole window. In order to do the brickwork the false-work would have to have been built first, so someone would have to have laid it out before construction. You can determine what that layout is.
You can steam bend the part you had highlighted in the pic however I would be inclined to do a bent lamination. If you choose to do a steam bend remember to over bend to account for the springback.
Old 06-04-2012, 09:08 PM   #11
Rewards Points: 20
Here is a picture from further away so you can see the entire arch.
Old 06-04-2012, 09:17 PM   #12
DIY staff
A band saw sure would help you on that project---
Old 06-04-2012, 09:20 PM   #13
recently retired
Rewards Points: 280
It appears to be a lancet arch with a slightly modified top. The spring line looks as if it breaks on the inside edge of the inner style/mullion. Find the center of the arch from baseline to break in springline to see if it is true, as I suspect it is. From there you can make the piece you need. Hard to tell from the pic if the top of the arch is a one, two or three point curve.
Old 06-04-2012, 10:39 PM   #14
Haverhill Trade 1965
I think I would try to make a close fit template from a wider board, and hold it against the window, then use a pair of dividers, (compass) set to 1/2 the width of the jig saw table and scribe the arc. Cut the board with the jig saw, maybe sand it to take off rough spots, then fasten it on top of the pieces you want to use and run the jig saw against the template. That should help guide the cut to avoid most of the variations of a free hand cut. It should be close enough to sand it to fit from there
Duckweather is offline   Reply With Quote
Old 06-05-2012, 06:31 AM   #15
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Vinyl Trim = very flexible (more-so than unheated PVC).
- Build Well -
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
