Custom Wall Tv Unit - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 08:59 AM   #1
Custom wall tv unit
Hello Al,
this is my first post, i'm currently brainstorming about building a custom wall unit for my condo which i will get into on the first of October.
I saw in a paper a custom shelf build with all different cube / rectangles.
What i'm hoping to build is some sort of shelfs that hang just below my plasma tv. I was thinking of making boxes to accomodate all my different tv component such as receiver, speakers, remote, blu ray, dvd, xbox and satelite receiver. I have this picture in mind but the design i would look for would be cube below the tv, and a column ( a bunch) of cube on the right hand side with all different shapes.
I hope my english isn't confusing oyu guys (i'm a frenchy)
Questions i have -
Should i used mdf 1/2 '' or 5/8 ''?
I'm planing of gluing the cube together, should i also use nails or screw?
How would i go about mounting all that stuff on a wall, would mdf be strong enough to hold.
* I have taken some woodshop classes back in hoghschool, and i have access to a full woodshop where i work*
Any recommendations are also appreciated.
laflsyl10 is offline   Reply With Quote
Old 08-26-2011, 04:27 PM   #2
Rewards Points: 5,336
What type of wall is it? Studded with wood? Metal?
I'd use a birch plywood instead on MDF. MDF is very heavy and has little structural stiffness. Long horizontal runs will sag.
I'd glue and nail it.
Ron
B. Franklin 1759
Old 08-26-2011, 04:38 PM   #3
Don't call me Al! Just kidding, your English is better than my French.
Birch plywood has a nice finish on both sides although MDO (good 2 sides) might be a little cheaper. I like to make the sides deeper than the shelves so I can rabbet the back to cover the back panel (I assume you're putting a back on it).
If you're using plywood or other sheet material, you'll need to apply a face frame or veneer to the raw edges of the plywood. I'd use 3/4".
I also try to paint the components before assembling them
mrgins is offline   Reply With Quote
Old 08-31-2011, 02:20 PM   #4
To respond to the two above posts,
i did glue and nailed the pieces togetger, The wall is framed, althought i don't know what it is framed with.
I might have to restart and plans things out better. Things look great but as one mentioned, long runs might start to sag.
I was thinking on installing drywall anchors and hanging and L shape hanger to the bottom each cube, that way i can get a good support from the walls. (some anchors are rated a 75lbs each)
Thanks for the suggestions guys.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Fujitsu Halcyon AC wall unit dribbling water out of vents Big Murth HVAC 2 07-03-2010 02:50 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
