Custom Office Desk U Shape Materail? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 04:21 PM   #1
Hello.
I'm trying to design and build a custom made U shape office desk. It'll be 108"x108"x108" 30"W top. (I need the top surface to be strong and dent/scratch resistant for building computers on as well as a surface for writing ect.)
I'm looking for somthing farely cheap. Currently in my work office they use what looks to be 3/4" Particle board with a laminate finish on top and use 14"x30"x4" x 1/4" thick angle that gets bolted to the wall and supports the desk. I don't really need to many drawers or anything just want a flat surface.
What wood/mdf ect should I use that will look modern but not kill the budget?
Matt
mfleming is offline   Reply With Quote
Old 10-21-2008, 05:19 PM   #2
Registered User
Termite's Avatar
It'll need to be a couple thicknesses of 3/4" material. MDF is very common, but can sag if not supported somehow. Plywood would also work.
You might consider melamine. It is the white-faced particle board. Probably $20/sheet.
The other option would be laminate, which runs about $50/sheet in addition to the MDF sheets and contact cement.
The box stores have pre-made counters you can order or buy off the shelf. For a durable surface, you can't do it yourself for less money.
Old flip top school desk Zarack Carpentry 15 09-09-2008 10:57 PM
Custom Corner Desk fungku Project Showcase 1 08-19-2008 08:01 AM
