Custom Made Door Trim - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 06:36 PM   #1
Rewards Points: 1,062
Question
custom made door trim
the trim that comes on the plain regular flush indoor door from HD is too wide (1-3/4" from the jamb) for my application and i need to take it off and put something that is 1.5" on both sides exactly cause it goes at the end of a hallway and i have very limited width.
as opposed to it being currently tapered on the door side and thicker on the outside, i plan to not have that, i.e. very simple rectangular, which also looks more modern.
questions:
1. should i use regular SPF 1x lumber or should i invest in something sturdier to prevent possible warping? maple or poplar, perhaps?
2. should i kerf each trim strip to prevent possible warping?
thanks
Old 02-22-2012, 07:01 PM   #2
Rewards Points: 636
paint or stain
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-22-2012, 07:07 PM   #3
Will it be painted or is it going to be stained ? If paint I recommend poplar or aspen they both take paint very well. If staining I would match the jamb/door material or base material. As far as the kerf issue, if nailed properly warping should not be an issue.
kj6887 is offline   Reply With Quote
The Following User Says Thank You to kj6887 For This Useful Post:
amakarevic (02-22-2012)
Old 02-22-2012, 08:47 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,212
if you have a table saw just remove the trim and rip it down to the width you need. this is a standard procedure for any carpenter who does trim work
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
amakarevic (02-22-2012), mae-ling (02-23-2012)
Old 02-22-2012, 09:12 PM   #5
i do have a table saw and was thinking about it but i also kindof don't like the shape of the trim it comes with (teardrop shaped in cross-section, tapering). i would like it more geometrically simplistic.
but thanks
Old 02-22-2012, 09:19 PM   #6
Originally Posted by jaydevries View Post
paint or stain
paint
Old 02-22-2012, 10:37 PM   #7
Rewards Points: 636
use finger jointed preprimed trim if it was me
Old 02-23-2012, 12:04 AM   #8
why would a narrow piece like this need to be jointed? i also noticed the original trim is jointed and would like to know the reason why as opposed to using a single piece of wood.
thanks
Old 02-23-2012, 01:33 PM   #9
Rewards Points: 2,212
Can you get 'Knock Down" doors? they come unassembled and without trim up here.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
amakarevic (02-23-2012)
Old 02-23-2012, 04:48 PM   #10
Rewards Points: 636
cost and stability same as a cabinet door it has multiple pieces glued together to prevent warp and cupping
The Following User Says Thank You to jaydevries For This Useful Post:
Old 02-23-2012, 04:55 PM   #11
You might want to look in the millwork department for what is called a "mull strip". These are about 1/4" thick and can be bought in different widths. This will give you the geometric shape without having to cut down 3/4 stock.
MNsawyergp is offline   Reply With Quote
The Following User Says Thank You to MNsawyergp For This Useful Post:
Tags
door , door trim
Garages - Can they be made mouse proof? JackOfAllTrades Building & Construction 14 11-27-2011 10:13 PM
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 01:10 PM
I need help wiring my home made kiln (240 VAC) onemachine Electrical 10 05-10-2011 09:33 PM
Custom Shower Curb nelsonc2121 Tiling, ceramics, marble 23 02-10-2010 04:43 PM
Just made me sick! Thurman Off Topic 26 12-10-2009 03:45 PM
