Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-31-2009, 10:20 AM   #16
Cabinet maker
Augie Dog's Avatar
I use 3/4" C-2 maple plywood with a MDF cross band for paint grade cabinetry.
The MDF is a 1/8" thick layer under the finished skin. The center cores are made of poplar.
One of the benefits of this type of plywood is that there is no "telegraphing" of the grain from the layer below the finished skin. Not all plywood has the same quality of core. Some has more voids than others and the contours of what lives below definitely shows through the finish, more so on a high end paint job than any other finish.
I like to use Maple for all the solid stock as well. It is hard and holds paint real well. A lot of cabinetmakers will use poplar for their frames as it is cheap, machines well, easy as heck to sand and holds paint very well. It is just too soft for my tastes. I will use poplar for crown moldings and other add ons that up and out of harms way.
For hardware I use Blum. Their Tandem drawer slides have changed the industry standard to full extension with soft close action. They have everything you need in hinges as well. Google is your friend for that.
Just like others have said, a combination of joinery is where you will end up. Don't under estimate the power of a butt joint and pocket screws or standard screws. You can almost always find a way to get by with one or the other. Adding dados is fine if you can comeup with a system that doesn't drive you crazy.
The most important element of cabinetry is your ability to break down your sheet goods into nice and square parts without any tear out of the finished skin. You need a good table saw and a cross cut sled as a minimum. Google cross cut sled and there are good plans available.
Nothing to this stuff, anyone can do it.
We just spent the last two days installing this paint grade job. Has all the materials mentioned.
Have fun and be safe
Augie Dog is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about types of materials. The first material that we are going to be working with is a 3/4 inch birch that is cabinetry grade. Now the reason why we chose birch is that it... Read More »
With its clean lines and simple design, the Parsons table has become a timeless piece of furniture. Attributed to Jean-Michel Frank from New York's Parsons School of Design, this table was first introduced in the 1920s. Add style to any room by making a... Read More »
Hi! My name is Jon on behalf of Expert Village. In this video clip, I will be talking about types of materials. The first type of material that I will be using is a 3/4 inch oak plywood. Now this is going to be used for my sides, the top, the bottom and... Read More »
Now in this clip we're going to look at different species of woods. Hardwoods and Softwoods, and talk about their different characteristics. Let's take a look. Now this particular example is Birch. It happens, this happens to be plywood. You can see that... Read More »
Today I will show you how to make this beautiful decoupaged hand mirror. Here are the materials we'll be using to make our decoupaged hand mirror. You'll want to choose from the amazing verity of napkins that they have in the stores now. To pick the... Read More »
built under oven uptonpark10 Building & Construction 0 05-29-2009 02:17 PM
Custom built legs for very large glass tabletop joeyboy Project Showcase 8 10-07-2008 12:48 AM
built under oven as a built in one? helen30 General Discussion 3 01-27-2008 05:15 PM
Prefab or custom stairs? brokie General Discussion 1 01-21-2008 09:11 PM
Site Built (custom) windows BigJimmy Building & Construction 1 04-01-2007 09:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
