Curved Wooden Path - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 05:32 AM   #1
Question
curved wooden path
what is the quickest way to make a wooden path in the shape of an arc around a semi-circle? the radius of the circle is 5 meters, but the path spans only the last 2 meters. i know you can work out the difference inbetween the widths of the planks at each end, cut each accordingly and make the perfect arc. but i would like to use whole planks as much as possible.
i was planning to cut some of much planks in half on the angle(not to a point though) and adding these in every so often to follow the curve and then just use a jigsaw at the end to create the perfect circular pattern on either end....
the top surface is going to be glued and a matting is going on top so doesnt have to look perfect. would this work?
funathome is offline   Reply With Quote
Old 10-03-2010, 04:00 PM   #2
Using 2X12 planks cut down the center at a suitable angle would be my approach.
Just one cut would be required for each pair of planks.
European Hinges for Curved Kitchen Cabinets thiftyspender Carpentry 2 04-20-2016 08:00 AM
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Installing laminate in a room with one big curved wall (PICS) vu321 Flooring 9 06-04-2010 03:15 PM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
4x4 wooden support post Harbog Carpentry 2 02-16-2009 12:39 PM
