Curved Stairs - Carpentry - Page 6 - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 03:26 PM   #76
should I call you ??
david f is offline   Reply With Quote
Old 03-21-2011, 07:55 PM   #77
recently retired
Rewards Points: 280
There can be a few contributing factors-
How tight is the curve
how thick are the plys
What type of wood are you using
Don't bend on a finger joint
Are you using a bending caul
How close is the clamp spacing
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
BigJim (03-21-2011)
Old 03-21-2011, 10:06 PM   #78
14 " 12 " apart clamps tight on one part like in my photo
Old 03-22-2011, 09:55 AM   #79
recently retired
Rewards Points: 280
The spacing of your clamps is too far apart but there are probably other contributing factors.
Old 03-22-2011, 10:23 AM   #80
maybe I should try a steam box ??
Old 03-22-2011, 10:39 AM   #81
recently retired
Rewards Points: 280
It may be that you need to steam but probably not. Get a book on steam bending and it will show why your piece broke.
Old 03-22-2011, 10:43 AM   #82
should I try to bend all the pieces together ?
Old 03-22-2011, 10:44 AM   #83
recently retired
Rewards Points: 280
Depends on how much extra material you bought
Old 03-22-2011, 10:47 AM   #84
maybe I should call you ?? email your phone # if so pls.
Old 03-22-2011, 08:13 PM   #85
I bough 14 " I need only 12
Old 03-22-2011, 09:02 PM   #86
recently retired
Rewards Points: 280
David,
What is the radius at it's smallest point?
I'm assuming you bought 6010 rail, did you buy the clamping caul that goes with it?
What are you using as your clamping platform?
Old 03-22-2011, 09:27 PM   #87
clamping caul no I bough the rail the peaces are 1/4 thick email me so I can attach my photo so the rad.. info@reval.ca
Old 03-22-2011, 11:39 PM   #88
recently retired
Rewards Points: 280
After looking at the pic you sent, unless this is an old pic you are nowhere near ready to start thinking about handrail. The curves don't appear to be very tight so bending rail should be fine. You will need to re-frame some of the curve to have a platform to bend to. Remember not to use glue with cold creep and to over bend. One foot of extra rail on each end is not going to be long enough.
Old 03-23-2011, 06:10 AM   #89
that is a old photo
Old 03-23-2011, 06:24 AM   #90
kwikfishron's Avatar
Rewards Points: 186
I see no photo, if you’re going to have this conversation in private, fine.
If the conversation is in the forum you should include all of it so others can see, learn and/or contribute.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (03-23-2011)
Tags
curved stairs
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Outdoor stairs need to be fixed... 2031pratt Carpentry 4 12-01-2011 06:55 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
