Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-02-2007, 10:06 PM   #1
Question
Curved Deck Stairs
I see alot of ads where there is man made deck material used to make curved steps coming of the deck. Does anyone have any experience doing this? If so where do I look for framing prints? Any do's or don'ts for this kind of project? Thanks
wibass is offline   Reply With Quote
Old 07-03-2007, 06:23 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Curved Deck Stairs
You would have to make the stringers so that the steps "arch" or radius out at the center (the middle area). The stringer ends (riser faces) would have to be cut at a degree in order to accomodate the bend of the composite material used for the risers. This is generally not the easiest build for a DIYer or first time deck builder to accomplish. You may want to consider hiring someone to build the steps for you (just a suggestion).
Anyway, this may help you. It shows how to make the framework for a curved deck. Fabricating a set of curved steps is similar in dealing with composite materials. You could study the info. to gain an understanding of the concepts of using composite material and sub-framing - when configuring radius areas. Tie that in with the concepts of Stair building (Primarily Stair Stringers):
http://www.taunton.com/finehomebuild...c-decking.aspx
Downloadable PDF version:
http://www.taunton.com/finehomebuild.../021111064.pdf
Stairs:
http://www.hammerzone.com/archives/f...rs/outdoor.htm
- Build Well -
Old 07-05-2007, 09:15 PM   #3
Extreme DIY'r Adk's, NY
Curved Deck Stairs
looks like fun!
crecore is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 08:16 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Deck stairs gmjosey Carpentry 1 06-08-2006 07:34 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
