Cures For Squeaky Stairs? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 08:54 AM   #1
The top 5 or 6 steps squeak. It drives me crazy. Any DIY fixes? No access to underneath, just a shallow pantry below.
g1hrtr is offline   Reply With Quote
Old 05-01-2013, 10:09 AM   #2
Old School
Willie T's Avatar
You said "5 or 6"... which indicates that you do not know for sure if it is 5 or 6. That could mean that your squeak is not necessarily coming from the individual treads. It COULD be the upper attachment of the center stringer (if there is one) or the upper attachment of either side stringer... or anything in between.
No matter where the squeak is, you first need to determine WHERE it is. Use a Listening Tube for this, not just your open ear. Listening Tube? Stick one end of a small rubber tube in your ear, and move the other end around like a doctor with a stethoscope, till you find the exact location/s.
Then, and only then, will you have a fairly accurate idea of what you are working with.
Willie T
Old 05-01-2013, 10:20 AM   #3
Counting from the top, it's steps 2-5. I do know that I can step on either far edge of the tread and there's no noise, only happens in the middle.
Old 05-01-2013, 10:26 AM   #4
House built in 1985, if that helps.
Old 05-01-2013, 10:34 AM   #5
Old School
Willie T's Avatar
One thing could be positive in this. The squeaks may serve as a warning if a burgler is trying to sneak up your stairs one night.
Willie T
Old 05-01-2013, 05:10 PM   #6
Rewards Points: 502
Have a look at this.
All you need to know to fix squeaky stairs (and somthing interesting as well!).
tony.g is offline   Reply With Quote
Old 05-02-2013, 08:44 AM   #7
Good thinking, way to look at a liability as an asset
jessrj is offline   Reply With Quote
Old 05-02-2013, 09:59 AM   #8
Roofmaster
Rewards Points: 2,210
You need to have access from behind the stairs to correct the problem. You can buy small steel Simpson Angle cleats at a box store and screw a few of these between the riser and the treads. This should help. Using steel brackets or angle iron will positively limit the penetration, unlike wood. Use HWH self tapping (Not self Drilling) screws. If the treads and risers are oak or maple, pilot drill with a depth stop. (Collet) and put some wax on the screw threads.
Need help with stairs rogers_t Carpentry 11 02-26-2013 11:30 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 12:09 AM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 07:45 PM
