-   -   Cures For Squeaky Stairs? (http://www.diychatroom.com/f14/cures-squeaky-stairs-178198/)
g1hrtr 04-27-2013 08:54 AM
2 Attachment(s)
The top 5 or 6 steps squeak. It drives me crazy. Any DIY fixes? No access to underneath, just a shallow pantry below.
Attachment 69866
Attachment 69868
Willie T 05-01-2013 10:09 AM
You said "5 or 6"... which indicates that you do not know for sure if it is 5 or 6. That could mean that your squeak is not necessarily coming from the individual treads. It COULD be the upper attachment of the center stringer (if there is one) or the upper attachment of either side stringer... or anything in between.
No matter where the squeak is, you first need to determine WHERE it is. Use a Listening Tube for this, not just your open ear. Listening Tube? Stick one end of a small rubber tube in your ear, and move the other end around like a doctor with a stethoscope, till you find the exact location/s.
Then, and only then, will you have a fairly accurate idea of what you are working with.
g1hrtr 05-01-2013 10:20 AM
Counting from the top, it's steps 2-5. I do know that I can step on either far edge of the tread and there's no noise, only happens in the middle.
g1hrtr 05-01-2013 10:26 AM
House built in 1985, if that helps.
Willie T 05-01-2013 10:34 AM
One thing could be positive in this. The squeaks may serve as a warning if a burgler is trying to sneak up your stairs one night.
tony.g 05-01-2013 05:10 PM
Have a look at this.
http://www.youtube.com/watch?v=dRoCUl4sSDA
All you need to know to fix squeaky stairs (and somthing interesting as well!).
jessrj 05-02-2013 08:44 AM
Good thinking, way to look at a liability as an asset:)
jagans 05-02-2013 09:59 AM
You need to have access from behind the stairs to correct the problem. You can buy small steel Simpson Angle cleats at a box store and screw a few of these between the riser and the treads. This should help. Using steel brackets or angle iron will positively limit the penetration, unlike wood. Use HWH self tapping (Not self Drilling) screws. If the treads and risers are oak or maple, pilot drill with a depth stop. (Collet) and put some wax on the screw threads.
