Crowned Floor Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 12:23 AM   #1
First time home buyer
Thirdeye's Avatar
Crowned Floor Joist
I want to install hardwood flooring in the mid level (where the kitchen/dining/living room are) of my tri-level home but there is a hump in the kitchen floor. After going into the crawl space to investigate, I discovered that one of the joists in the floor was bowing upward, causing the hump. How do I correct that? Do I have to replace the joist? Thanks in advance.
Thirdeye is offline   Reply With Quote
Old 03-04-2007, 06:50 AM   #2
If the crown is less than about 3/8" you can just sand it down with a belt sander. Take a look in the crawl space to see if anything is forcing the joist up,beam,stub wall. If it's really bad you might have to pull the sub floor and plain down the joist but that's not much fun.
They sure don't build them like they used to.
krazy johnni is offline   Reply With Quote
Old 03-04-2007, 04:37 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If the hump is significantly large, aside from removal and replacement, you could also:Open up the floor over it. Snap a chalk line across the top of it - to determine the extent of the unusual hump. Then take a power planer to it....(as Krazy johnni suggested)
- Build Well -
Old 03-04-2007, 05:24 PM   #4
Thirdeye's Avatar
A book I was looking in at Home Depot today talked about "sistering", where you cut the joist in two at the apex of the hump, let it settle back down over the next few weeks and then bolt a "sister" joist next to where you made the cut.
Are you familiar with that procedure? Does it work?
Old 03-04-2007, 05:55 PM   #5
I understand what you are saying and that would eliminate the point of tearing up your flooring.
Key would be to do it right and make aure that all weight is off that area...
Sounds feasible to me.....
- Build Well -
