Crown Woes - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 10:00 PM   #1
Crown woes
Have a 4' section on a "bump-out" that has 18" return walls back to the rest of the room. Am installing crown around room using 3 & 5/8" crown. About halfway around room, not much trouble till this windowed bump out! Left return outside corner is 92, left inside is 88, right inside is 90 and right outside corner is 94. The 4' section above the window is not level, has 2 big dips in ceiling making a straight edge wobble when placed on the ceiling, one at 6.5" in the other at 14"...I think from water damage to ceiling at one time. This causes the crown to be 1/4-3/8" below ceiling at either end. Have tried for 3 days putting up crown, trying to cope the left inside corner..no magic so far. Help! I am at the point of using corner blocks but I hate to give up now! How do you work these kind of wonky areas?..
Cheers,TC
tc909 is offline   Reply With Quote
Old 03-21-2013, 10:06 PM   #2
Rewards Points: 13,228
Got a picture?
Old 03-21-2013, 10:34 PM   #3
Its too dark now to take a good one..will do tomorrow.
Old 03-22-2013, 10:17 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
the best trick to work crown to a wonky ceiling is to shave some out of the back top side of the crown where it hits the ceiling. this alters the profile some but sometimes not to noticeably. also, when cutting crown I always lay it on the flat, you can make minor adjustments to the angles on the saw and lock them in on the saw which helps a whole lot. some crown is cut thirty times install one time
hand drive is offline   Reply With Quote
Old 03-22-2013, 10:30 AM   #5
Haverhill Trade 1965
Without pictures, the simple math would suggest 46 degrees each for left outside miters and 47 for right. The left inside corner would suggest 44 degrees for the cut to give you the cope line, but it may still work with 45 with more back cut. The front piece you may have to set with top space at corners equal and scribe the sag with dividers or compass. A block the same width as with a snug fitting sanding belt might form any irregularities if cuts are close.
Duckweather is offline   Reply With Quote
Old 03-22-2013, 02:56 PM   #6
Here's a couple of photos, but I don't know how much they will help. I wanted to show the ceiling with a level across it and the angle finder on the corners, but it turns out I can't hold the camera back far enough and hold those things up there at the same time!
http://i1276.photobucket.com/albums/...ps82d3efeb.jpg
dukes909 is offline   Reply With Quote
Old 03-22-2013, 02:58 PM   #7
Sorry, link should have been:
http://s1276.photobucket.com/user/tc...3efeb.jpg.html
Old 03-23-2013, 09:42 AM   #8
AHH, SPANS!!!
that should not be to bad to work out, fine tune the angles such that they fit in the corners. plan on running up and down the ladder with little test pieces, they are the simplest way to get a tight fit sometimes. if you have a compound miter saw lay the crown flat on the backside and use the pre designated crown slots on the saw( 31.6 Miter and 33.9 Bevel) to make the cuts and adjust at tiny amounts to fit the odd angles...
Old 03-23-2013, 01:03 PM   #9
Once you get the cuts figured out I would install the right and left pieces first, make the center piece a sixteenth long, put one end in, bow the middle outward until the second corner slides in and release the bow. The pressure will make a tight fit and sometimes compress the joint and close any tiny gaps. Be sure to keep plenty of pressure on the first end so it doesn't pop out as you bow the piece.
Tags
crown , miter , trim
What size nails for kitchen crown molding? mystic_cobra Carpentry 14 11-17-2011 12:22 PM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 03:41 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 10:40 PM
