Originally Posted by Yeti
I am puting up some crown moulding in my family room and I need to put up a nailer strip on two of the walls. What have you guys found that works best for this?
I'm not sure that I follow you? Do you mean a nailing 'cleat'?
Also, if you are installing paint grade trim do you usually cope the inside corners, or do you miter and use painters caulk if necessary?
It depends on your 'coping' abilties. Coping the cut always is the best method. If you find this is just too difficult for you, then go a head and miter cut and use caulking....
