Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-15-2008, 06:23 PM   #16
Licensed Contractor
Crown moulding with a vaulted ceiling?
Gary Katz is a finish carp that now takes his craft on the road, DVD, web, and anywhere else he can make a buck telling everyone else how they should trim a house. Which sounds negative, but is not intended to be. He's a good guy, and absolutely knows what he's talking about; he's kind of the finish carps guru.
This is an article he wrote on this subject. It's worth the read, even if you don't think you want to do this now, but someday might:
http://www.garymkatz.com/TrimTechniq...ansitions.html
Renovator,LLC is offline   Reply With Quote
Old 07-29-2008, 12:28 PM   #17
i have done a lot of crown moulding and it is no problem for me.but i just went to look at a new job and it was a vaulted ceiling.the transition piece looks like crap to me. I was wondering if there is any way to mathematically figure it out?
dcoyconstuctor is offline   Reply With Quote
Old 03-01-2010, 04:08 PM   #18
Newbie Bill
Hey Guys,
I googled "crown moulding on a vaulted ceiling" and my trusty DIY site popped up. Great info.
I also found this site.
http://www.extremehowto.com/xh/artic...ticle_id=60354
Anybody else have anything to add?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 04-11-2010, 02:54 PM   #19
Installing crown molding on a flat ceiling is challenging enough. I have intsalled crown molding on vaulted ceilings before. I've actually done this in my own great room. It looks beautiful, but does take an incredible amount of patience and skill. This task cannot be completed without the use of a coping saw. Because you will likely have a flat piece running along one wall and a piece running along the vaulted wall, you need to first install the crown on the vaulted wall. If you have a 4/12 pitch, your angle cuts on both ends would be 8 degrees. Now comes the challenging part. Where the crown meets the corner of the vaulted crown, you will need to cut the end of the flat crown to match up to the face of the vaulted crown. This is where the coping saw is necessary. I like to refer to this cut as a "beveled compound miter". I highly suggest making yourself a cardboard template, so you can tranfer the shape to all of your corners. It will work for either side of your room by simply flipping the template over and using the other side. Also, after you have cut the shape from the end of the crown molding, you will need to use your coping saw again to make a 45 degree back cut along the shape. Imagine cutting a 45 degree bevel while your molding is standing on end. If you did this with a chop saw, you would achieve the back cut, but you wouldn't be able to follow the shape. This will take some patience and practice if you haven't used a coping saw before. Now the flat piece should match the face of the vaulted piece in the corner where the two meet. If you get it close, don't worry too much about perfection. This will become complete when you fill the corner with wood putty, sand and paint to finish. You will have a beautiful finished ceiling line.....I promise. Good luck and may God bless your home!
Carpenter23
carpenter23 is offline   Reply With Quote
Old 04-12-2010, 02:25 AM   #20
Hi Chuck
How is the ceiling vaulted?
I’ve seen crown molding flanking the arched center section of a three parts ceiling. If it’s a barrel vaulted ceiling, I can tell you it looks classic.
Lloyd
officedeskreviews
LloydBurrell is offline   Reply With Quote
Old 04-12-2010, 09:23 AM   #21
Jay123's Avatar
This bears repeating
Jay
Jay123 is offline   Reply With Quote
Old 04-12-2010, 04:22 PM   #22
Gary Katz' method is usually the one used by the amateur because the supposed "correct" way to do it is by using two different trim profiles. The raking crown is an elongated version of the horizontal crown and the spring angle must be changed. Most DIYers aren't willing to spend the money to get the new profile milled for the vault, so they do it with a transition piece. Doesn't look right to me, but it is one way to do it.
Personally, if I couldn't do it the right way, then I would either use corner blocks or nothing at all.
Cache is offline   Reply With Quote
Old 04-12-2010, 04:41 PM   #23
Jay123's Avatar
I haven't seen any "amateurs" trying gary's method...and remember this is d.i.y. not "carpentry gods"
Jay
Old 04-21-2010, 04:55 PM   #24
Knows everything but that
I used the above method and I had never touched a piece of crown molding. It wasnt too bad. Granted, my wife and I almost got divorced over it but it looks nice now. I dont believe that my ceiling would have worked any other way... The book and the angle finder were too confusing so I just trial and errored through one piece and saved the settings that worked, marked the pieces as templates and wa-lah!
Shane
JakAHearts is offline   Reply With Quote
Old 04-21-2010, 06:53 PM   #25
i've done crown where the wall hits the vault ceiling line then carried it horizontal at the same elevation on the gable sides. we then installed strings of led up lighing behind the crown. nice effect
The older I get the better I was
Old 04-21-2010, 07:24 PM   #26
Newbie Bill
JakaHearts and Tpolk,
Please post photos.
Bill
The Following User Says Thank You to drtbk4ever For This Useful Post:
Jay123 (04-21-2010)
Old 04-21-2010, 07:42 PM   #27
Its not perfect but I think it looks good enough for free labor!
Shane
Old 04-21-2010, 07:44 PM   #28
Jay123's Avatar
Not bad at all...if your labor is free...I can use some serious help with some lawn work this weekend
Jay
Old 04-21-2010, 08:06 PM   #29
Thanks! I forgot to mention this is Focal Pointe molding so its not wood. Its very flexible and I just brad nailed the upper edge to the gabled ceiling to take up the gap.
Old 04-22-2010, 11:00 AM   #30
Newbie Bill
Nice work JakaHearts,
Thanks for posting the photo.
Bill
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
Lighting tip needed for vaulted ceiling wease Electrical 5 02-25-2007 12:49 AM
Vaulted Ceiling Insulation Problem casey_wa Roofing 13 05-08-2006 10:55 AM
Vaulted ceiling molding KitSpring General Discussion 2 01-05-2006 09:19 PM
