I did a search but could not find the answer. This started out as simply a kitchen remodel, but now I guess we are redoing the whole house except for bathrooms. As we go through the house we are removing the textured ceilings, installing crown mouldings and painting. My question is, we have one room, a family room addition, with the same textured ceiling, but with a vaulted ceiling. Is it common practice to install crown where there is a vaulted ceiling? Would it look strange? I don't think I have ever seen it done. Wondered what you think.
Thanks.
Chuck
General rules are that you do not install the crown molding onto the vaulted areas of the ceiling. It just does not look right.
Usually, the crown is ended several inches short of the area - that starts the vault line. It is cut and returned back into the wall.
You could install some 1x boards on the wall and then double layer step-ed on the ceiling or just do the ceiling edge. Another option is to scape a even four inches of texture off all the ceiling edges and paint it the wall color.
i was just about to ask this same question. does anyone have any more pictures or has anyone attempted it? I have vaulted ceilings in my kitchen/ living room area and am really looking for a way to dress up the walls. I am not sure I like the idea of running the crown at the same height as the lowest portion of the wall. i will look for more pictures of that, but if anyone has any additional pics of that concept, i would greatly appreciate seeing them.
I have heard people on these forums say that it isnt right to crown a vaulted ceiling, but I have done it a few times and I dont think it looks bad. You should have some experience with crown installation before you do this. (specifically with coping the corners instead of mitering)
What I did was run the crown up the sides first, cutting the ends at an angle to match the wall angle....(make sense?)
then on the top, you just lean the crown outward to match up the cope to the side piece you already installed.
On the bottom, you need to lean the crown upward, (flatter to the wall), to match the cope.
You dont need to figure out any fancy angles because the ceiling is vaulted. You just use 45s like you would in a square, flat room. Try to visualize it like this:...you have 4 sticks of crown assembled on the floor in a square shape, nailed together at the corners. You then stand in the center of one of the sides and lift it into the air, the other side still resting on the floor. This is how it will be when it is in place in the room the room with a vaulted ceiling.
The problem with laying the crown flatter to the wall is the fact that when you do this, the bottom of the crown that is supposed to sit flat against the wall, seperates from the wall, leaving a gap. What I do to counter this is run the crown through my table saw to cut off the original step (whatever you call it) on the back side/bottom of crown. This creates a sharper angle that lays flat to the wall. After I have cut and test-fitted my pieces, I run a bead of latex painter's caulk along the back of the crown where it contacts the wall, top and bottom, to help adhesion. I do this with all crown, not just vaulted ceilings. In fact, I rarely even hunt for studs to nail into. I just glue the crown to the wall with caulking and shoot nails into drywall. When the caulking dries, you can prctically do chin-ups on the crown without it pulling off. Its pretty strong. Make sure to have a damp rag handy to clean any oozing caulking as you go. Don't let it dry. Try not to let it ooze at all by keeping the bead to the innermost part of the flat on the back of the crown. Then go back and caulk it properly after it's done. This method of crowning a vaulted ceiling is probably not a good 1st time crown job. Hope this helps.
I personally do not like crown up a vaulted ceiling, but many people do, and it can physically be done, although not a great first time DIY project. This is an installation that leaves a great many finish carpenters mumbling. It is either done with a transition piece as one response pointed out, or by using two different size mouldings, reripping the top and bottom angles of one, so that the moulding can be sprung off the wall at a different angle than the standard factory mill profile. Using tha same size for the flat and rake walls will result in the piece on the flat wall being almost completely flat, and quite obvious unless it is very high up. The different size moulding will allow you to cheat the angle enough to force the cope, yet still maintain enough spring angle from the wall to not be an eye catcher.
Here is a book that I purchased and it gives you very detailed instructions and several tables to use depending upon what the pitch of your ceiling is.
Does anybody have pictures of a vaulted ceiling with crown that is completed? We are building our house and are almost done and don't know what to do with our vaulted ceiling in the livingroom. help!
I think that krazy johnni has the best idea yet, but it looks pretty difficult.
I have the Crown and Molding book. Even with my engineering background and a lot of math courses, figuring how to accurately miter the corners with all the angles involved makes my head feel like exploding.
I was thinking of building a box at each corner, and just butting the molding up to the boxes. That would solve the problems of complex compound angle cuts and molding edges not matching up. The right size boxes with the right decorative appliqués should look OK in our very large room that vaults up to about 16".
The pinch-block corners is what I had in mind, except they look a lot easier to cut and install than the built-up boxes I had envisioned. Thank for the site.
Gary Katz is a finish carp that now takes his craft on the road, DVD, web, and anywhere else he can make a buck telling everyone else how they should trim a house. Which sounds negative, but is not intended to be. He's a good guy, and absolutely knows what he's talking about; he's kind of the finish carps guru.
This is an article he wrote on this subject. It's worth the read, even if you don't think you want to do this now, but someday might: http://www.garymkatz.com/TrimTechniques/cutting_crown_transitions.html
i have done a lot of crown moulding and it is no problem for me.but i just went to look at a new job and it was a vaulted ceiling.the transition piece looks like crap to me. I was wondering if there is any way to mathematically figure it out?
Installing crown molding on a flat ceiling is challenging enough. I have intsalled crown molding on vaulted ceilings before. I've actually done this in my own great room. It looks beautiful, but does take an incredible amount of patience and skill. This task cannot be completed without the use of a coping saw. Because you will likely have a flat piece running along one wall and a piece running along the vaulted wall, you need to first install the crown on the vaulted wall. If you have a 4/12 pitch, your angle cuts on both ends would be 8 degrees. Now comes the challenging part. Where the crown meets the corner of the vaulted crown, you will need to cut the end of the flat crown to match up to the face of the vaulted crown. This is where the coping saw is necessary. I like to refer to this cut as a "beveled compound miter". I highly suggest making yourself a cardboard template, so you can tranfer the shape to all of your corners. It will work for either side of your room by simply flipping the template over and using the other side. Also, after you have cut the shape from the end of the crown molding, you will need to use your coping saw again to make a 45 degree back cut along the shape. Imagine cutting a 45 degree bevel while your molding is standing on end. If you did this with a chop saw, you would achieve the back cut, but you wouldn't be able to follow the shape. This will take some patience and practice if you haven't used a coping saw before. Now the flat piece should match the face of the vaulted piece in the corner where the two meet. If you get it close, don't worry too much about perfection. This will become complete when you fill the corner with wood putty, sand and paint to finish. You will have a beautiful finished ceiling line.....I promise. Good luck and may God bless your home!
I’ve seen crown molding flanking the arched center section of a three parts ceiling. If it’s a barrel vaulted ceiling, I can tell you it looks classic.
Gary Katz' method is usually the one used by the amateur because the supposed "correct" way to do it is by using two different trim profiles. The raking crown is an elongated version of the horizontal crown and the spring angle must be changed. Most DIYers aren't willing to spend the money to get the new profile milled for the vault, so they do it with a transition piece. Doesn't look right to me, but it is one way to do it.
Personally, if I couldn't do it the right way, then I would either use corner blocks or nothing at all.
I used the above method and I had never touched a piece of crown molding. It wasnt too bad. Granted, my wife and I almost got divorced over it but it looks nice now. I dont believe that my ceiling would have worked any other way... The book and the angle finder were too confusing so I just trial and errored through one piece and saved the settings that worked, marked the pieces as templates and wa-lah!
i've done crown where the wall hits the vault ceiling line then carried it horizontal at the same elevation on the gable sides. we then installed strings of led up lighing behind the crown. nice effect
Not bad at all...if your labor is free...I can use some serious help with some lawn work this weekend :laughing:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
