Crown Moulding Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 08:46 PM   #1
crown moulding question
Im looking to purchase 7" crown moulding. I wanted to know if anyone had any idea how many inces from the top of the wall/ceiling a 7" crown moulding would go down to once instaled? i'm just making sure i have enough space up top in a few areas. If anyone could answer that, I would appreciate it.
Thanks,
Greg
gbonomo is offline   Reply With Quote
Old 03-21-2009, 08:55 PM   #2
depends on the spring angle. find that out and I can answer your question
II Weeks is offline   Reply With Quote
Old 03-22-2009, 02:28 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by gbonomo View Post
....... i'm just making sure i have enough space up top
The best way to make sure, is to get a sample 12 inch piece and try it out. Make sure you try it with the right side up. If there is any question of which side is Up?, then have the dealer mark the sample for you.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-22-2009, 02:13 PM   #4
Old School
Willie T's Avatar
As you are being told, this will vary a little bit with the spring angle, the specific profile tips, even the manufacturer.
Some 7" crown is less than 7", some can be more than 7". There are a lot of variables.
But here are a few numbers you can put in the back of your head as ballpark figures..... as distances out onto the ceiling. Use the opposite numbers for wall hangdown.
38= about 4 3/8" You're pretty safe figuring 4 1/2"
45= about 5", give or take a quarter or so.
52= about 5 9/16" Somewhat safe at 5 5/8"
None of this is exact, it's all "give or take" a few fractions, so do like the others suggested, and get a little piece of EXACTLY the molding you intend to use, and measure it in place.
Willie T
Old 03-24-2009, 03:28 PM   #5
Drywall contractor
Rewards Points: 1,070
Hope you've got at least 9' (or better yet, 10') ceilings. Overkill for 8' ceilings. Your post mentioned "space up top" so I'm guessing you've got some fairly narrow soffits above?? Not worried about hitting on top of the door trim or something along those lines??
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Painting MDF crown moulding sk8z Painting 3 05-19-2008 05:11 PM
crown moulding painting WorkOnIt Painting 3 06-18-2007 11:56 AM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 05:50 AM
