Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-17-2012, 11:01 PM   #1
crown moulding question.....
I want to install some 3 5/8 mdf crown moulding. I painted my basement joists, hvac, pipes, etc black so we are going with modern bar/man cave theme. I want to install crown moulding about 12 inches below the joists so it will be floating. If I use my brad nail gun and 16 guage brad's every 16 inches on center will it hold ok? I was wondering if I needed to rip some wood to place behind the crown for extra support.
mikey1999 is offline   Reply With Quote
Old 09-17-2012, 11:26 PM   #2
cut some blocks the same angle as the back of the crown. we used to do that when we left the crown low for rope lighting. we nailed the crown up first then just put some pl on the blocks and slid them in gluing to the crown and the wall. we just did them like 2 feet apart but you could rip a piece and go full length if you wanted but its more work
Old 09-18-2012, 10:49 AM   #3
AHH, SPANS!!!
As DannyT mentioned add the blocks in later after attaching the crown or pop a chalk line on the wall and screw the blocks to the wall following chalk line and add crown to the blocks afterward. there are different ways. you could maybe even add a 1x shelf on top that sticks out some from the crown to give it a different look...
hand drive is offline   Reply With Quote
Old 09-18-2012, 10:55 AM   #4
#1, I would never use MDF in a basement. To high a chance of moisture causing it to expand and buckle.
If you used picture moulding instead of crown you would have the same look but no backing needed.
http://www.bing.com/images/search?q=...748CFE&first=1
Old 09-18-2012, 10:12 PM   #5
AHH, SPANS!!!
Indeed, even moving up to stain grade crown to avoid the finger joints is preferable in a possibly humid environment. nothing worse in crown than a finger joint showing and pulling apart from moisture...
Thanks for the picture and crown images pic link also
Crown Moulding - Inside corners. Moulding upside down? mb88 Carpentry 5 09-21-2012 05:37 PM
Azek crown moulding and vinyl siding Pittsville Building & Construction 6 02-06-2012 10:07 PM
Plastic baseboard vs crown moulding baseboards daluu General Discussion 17 01-29-2012 09:05 AM
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 10:15 AM
finish for crown moulding jacky Painting 8 01-10-2012 08:07 AM
