Crown Moulding - Funky Corner - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 08:18 PM   #1
Network Geek
Crown Moulding - funky corner
Hi everyone,
Because of a few reasons I am left with the below situation. It is a right angle wall/ceiling joining a wall that is say 45 degrees. I need to join the corners with crown. Any ideas to make this look good? BTW, I am going to re-cut the existing piece as it's not long enough anyway.
Thanks,
Thanks for anyone help you can provide.
Dive_Instructor
dive_instructor is offline   Reply With Quote
Old 07-28-2012, 09:02 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
I always built a little soffit like cornice to go across the angle which will square it up and then you will be able to run the ceiling mold on around like it was normal.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (07-29-2012)
Old 07-28-2012, 09:08 PM   #3
Network Geek
Thanks Jim. That idea has been brought up before. That is probably the best option as I stink at regular corners, let alone this one.
D.I.
Old 07-29-2012, 10:13 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
It is a 90 degree corner so a standard outside corner will work save for the wall on the right in the pic. For the piece of crown on the left I would cut the angle a little bit less than standard and cut the angle on the piece on the right a little bit more to accommodate the bottom wall angle. If you align the bottom corners tightly then the rest of the miter will work regardless of how the wall angles behind the crown, the outside corner of the crown will float past the wall angle. The trick here is to just think about the top and bottom of the outside corner of the crown and aligning those two points. Use small test pieces (template)to get it right and figure out the exact angles and then cut your final crown pieces. Plan on caulk to be used on the underside against the wall for the piece on the right because of the wall angle.
There is a little 3/8" or 1/4" flat section along the bottom backside of the crown where it beds against the wall. The top edge of the 3/8" flat will be where you want the two crowns to align when forming the outside corner. This is because of the wall angle on the right and the piece on the right at the bottom backside where it meets the wall will really only rest against the top edge of that 3/8" flat wall bed, do you understand?
hand drive is offline   Reply With Quote
Old 07-29-2012, 04:17 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
Could you post a picture of that?
Jim
Old 07-29-2012, 07:45 PM   #6
recently retired
Rewards Points: 280
I'm not seeing how that's going to work either.
Keith Mathewson is offline   Reply With Quote
The Following 2 Users Say Thank You to Keith Mathewson For This Useful Post:
BigJim (07-29-2012), oh'mike (07-29-2012)
Old 07-29-2012, 10:32 PM   #7
AHH, SPANS!!!
measure and cut 50 times! that is how it is going to work. A half day corner
seriously though, I'll refer back to the 3/8"flat on the bottom backside of the crown. If the OP were to bed a longer than needed piece of crown against the ceiling and wall on the left side and scribe with a pencil the 3/8 flat on the backside ( think plumb and not following the right wall angle) and mark on the wall corner where the top of that 3/8 flat planes across it, this is where the measurement for both pieces will be to. that is the trick, the one point where both crowns will meet at that outside corner. this can only work because the ceiling is level around the corner and the only discrepancy is the angle of the wall on the right. The crown on the right will just bed against the wall at the top of the 3/8 flat ( pivot if you were ) and the rest of the 3/8 will be plumb and at a 90 degree to the ceiling, not following the wall angle. The right piece will also rely more on the ceiling to bed against whereas the left piece can be bedded against both wall and ceiling correctly.
Old 07-29-2012, 11:41 PM   #8
recently retired
Rewards Points: 280
What you are describing is what jiju1943 is referring to as a soffit. When the spring angle changes on the wall which is not plumb then a "filler" piece must be added (the difference between the rake and plumb) or the molding must be a different size, there is a way of calculating that change of size but that is not what we are addressing here.
Old 07-30-2012, 07:43 AM   #9
AHH, SPANS!!!
If there is to be a filler piece needed it would be a small tiny rip that goes under the crown on the right against the angled wall, otherwise known as caulk if the space is not to great. It all depends on the crown profile and how much of a flat there is on the bottom backside, usually for most crown it's about 3/8 on the wall bed and 1/4 inch on the ceiling bed...
It can certainly be done no problem, I've crowned a room with multiple vaulted ceilings and cabinets involved and it was all stain grade. every outside corner going around those vaulted ceilings and cabinets was a major pain and a major learning experience..
Old 07-30-2012, 08:15 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
I understand what you are saying but I believe the different angle of the sheet rock will not let the top of the ceiling mold to lay back against the flat ceiling. I guess you could cut the sheet rock back so the top of the ceiling mold wouldn't touch the angle at the top.
Jim
Old 07-30-2012, 08:29 AM   #11
AHH, SPANS!!!
or either rip some of the back of the crown out just at the top back portion. I do not think the spring angle of the crown is less than the wall angle, they actually look really similar in angle so the crown may just lay nicely against the angled wall. There is also a gap on the angled wall at ceiling height so that might accommodate the crown a bit..
Old 07-30-2012, 11:41 AM   #12
Network Geek
Thanks for the discussion guys. Based on my crown cutting skills, it probably would be best if I just made a small soffit and positioned the crown like the others.
Honestly, I'm not really following or seeing how these two pieces could fit together and not look like garbage.
D.I.
Old 07-30-2012, 01:44 PM   #13
cut 2 scraps at a 45 and test fit them. i see no reason why regular cuts wont work , you are making a 90 degree turn. the sloped wall will not make a difference as the crown angles out anyway to clear the top of it. why is the piece on the right flat against the ceiling? you will have to recut the piece on the left tho to a 45.
Old 07-30-2012, 01:48 PM   #14
Network Geek
Hi Danny,
If I don't do it that way the bottom of the crown will be in the air and not against anything.
D.I.
Old 07-30-2012, 01:51 PM   #15
why would the bottom of it not ba against the wall? just put it against the wall like the other piece. nothing you can cut will fit the piece that is there now. there might be a slight gap because of the slant of the wall , but nothing that can't be caulked.
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 10:15 AM
How to match mis-matched crown moulding tooladdict Carpentry 5 10-13-2011 11:55 AM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 03:41 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
