Crown Moulding: Flat Ceiling To Angled Wall Question - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 09:35 PM   #16
beachbumz
RP31 how did your crown molding come out? Any photos?
beachbumz is offline   Reply With Quote
Old 02-15-2010, 09:43 AM   #17
Ben-g
THOSE CORNERS ARE CALLED BULL NOSE CORNER BEED.THEY ARE QUITE THE NORM DOWN HERE IN FLORIDA.AND THAT IS THE CORRECT WAY TO INSTALL BASE.RUN THE BASE TO WERE THR BULLNOSE STARTS ROUNDING.BACK ANGLE CUT TO THE ROUND AT 22.5.RUN THE OTHER SIDE THE SAME. IF YOU CAN,DRY FIT WITH EXTRA ON THE OTHER ENDS.THEN MESSURE THE BACK CUT ENDS AGAINST THE WALL. IT'S NORMALLY BETWEEN 5/8 AND 3/4 BACK CUT IT AT 22.5.DRY FIT IT.CUT ECCESS OTHER ENDS,HOT GLUE BULL NOSE.NAIL THE BASE FROM THE CORNER BACK. "DONE".IT'S NOT THAT HARD ONCE YOU DO A FEW OF THEM.
BEN-G is offline   Reply With Quote
Old 11-20-2010, 06:06 PM   #18
Originally Posted by KOHNSTRUCTION View Post
i have run into this crown problem numerous times.
some times it looks better ending into the angled area other times it really looks like it's missing and it should be there
one solution that i have used is to build down that angled area the height of the crown with some poplar or finished plywood to build almost like a step angled back to the stringer.
Then run the crows as if it was a flat wall going around the angled area.
it all depends on what you are doing, and what you are tring to do
good luck!
Wouldn't the bottom of that new "step" make the crown look wider underneath?
nel262 is offline   Reply With Quote
Old 10-30-2012, 04:15 PM   #19
Originally Posted by II Weeks View Post
Willie T, I saw what Basswood did there and thats some of the most impressive finish work Ive ever seen.
that guy does some great work
Thanks for the nice compliment. I found this thread via google images. I saw a photo of my work and wanted to see what was being said.
If you want to see more of my work, I just set up a FB page: http://www.facebook.com/basswoodartisancarpentry
Might be a few more ideas in there for you.
Regards, Bass
basswood is offline   Reply With Quote
Old 10-30-2012, 04:18 PM   #20
Originally Posted by Willie T View Post
Some of Basswood's work... and his inventiveness... is close to unbelievable. I think the guy's one of the best I've ever seen.
Thanks Willie. I just don't know how to avoid a challenge I guess.
Hope all is well, Bass
Crown on ceiling not 90 degree to wall Monju123 Carpentry 12 02-23-2013 12:09 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 11:42 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 02:16 PM
