Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-02-2011, 01:40 PM   #1
Crown Moulding
I am installing Crown mouldling. I want to cut it flat. I want to use a compound miter saw. My corners are 90degrees. My moulding angle spring is 45/45. What is my miter and bevel settings. THanks Wes
wasdewp1 is offline   Reply With Quote
Old 03-02-2011, 02:34 PM   #2
Experienced
Jackofall1's Avatar
Crown Moulding
Welcome Wes, to the best DIY'r site on the web.
Here is a table of angles needed for crown work.
http://www.sbebuilders.com/cgi-bin/g...pring_Angle=38
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
wasdewp1 (03-03-2011)
Old 03-02-2011, 03:25 PM   #3
Old School
Willie T's Avatar
Crown Moulding
Since you say all your corners are 90, here is just the section of my chart showing 90 and a few degrees to either side. (BTW, you will be just about the only person in the United States who has corners that are a true 90.)
Willie T
Willie T is online now   Reply With Quote
The Following User Says Thank You to Willie T For This Useful Post:
BigJim (03-02-2011)
Old 03-03-2011, 05:37 AM   #4
Crown Moulding
Thanks for information. I know that is wishful thinking on my behalf. Wes
Old 03-03-2011, 07:03 AM   #5
Crown Moulding
yep, no walls are perfectly straight, no angles are perfect anything. Those charts will get you in the ball park, but you still need to fine tune. I always have extra trim and make short trial pieces before cutting the long ones.
Old 03-03-2011, 07:22 AM   #6
Crown Moulding
thank you. This is my first time . All information give is great. I guess it would be to my advantage to cut some sample cuts and label them so I will have a reference. Inside/outside. Is the compound miter the best way to cut laying the moulding flat or should I just miter againt the fence with a 45degree. Thanks
Old 03-04-2011, 07:30 AM   #7
Crown Moulding
Samples will only work for the corner they are fitted to(no two corners will be alike), but can be used as a general guide. But that is a lot of samples to haul around. Once you get the hang of it, you can keep those samples in your head. All outside corners get a mitered joint, inside corners work better with a coped joint, it never opens up like a miter joint can.
Old 03-04-2011, 07:45 AM   #8
Crown Moulding
Thanks, Never thought about the joint opening up. Thanks again for all your help and knowledge. Wes
Old 03-05-2011, 07:43 AM   #9
Crown Moulding
Like he said. Cope all inside corners and whenever possible, assemble your outside corners on a table with brads and glue and go up as one piece. Huge time save and you can block behind the miter for more meat to nail into.
II Weeks is offline   Reply With Quote
Painting/staining crown moulding and chair rail Gypsy601 Interior Decorating 8 07-05-2011 04:51 PM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 03:41 PM
Everything was already painted, including the crown moulding! C_Sato23 Painting 6 09-23-2010 03:38 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
