-   -   Crown molding with window (http://www.diychatroom.com/f14/crown-molding-window-166996/)
Jeff180 12-20-2012 12:56 PM
1 Attachment(s)
How do you handle crown molding when a high window is in the way?
I've attached a picture of a possible solution and the molding I'm thinking of using. It's 4 5/8" crown with a picture rail set below it.
My thought is to run only the crown molding across the top, with returns on the picture rail so they "fall" into the window. The crown molding will probably hang down into the window by 1/2" or so. Would something like this look right?
Seattle2k 12-20-2012 02:45 PM
If you don't want to use crown with less width (height), then you'll have to run it across the window opening. Since you'll be left with a 5/8" overhang, you might want to attach a piece of flat/s4s moulding to the top of the window opening, between the window and the bottom of crown, to fill the space and provide a finished and intentional look. Play around with it and see how it look.
Personally, I wouldn't run the picture rail into the window opening. I would set my return to end right at the edge of the opening.
Jeff180 12-20-2012 03:04 PM
I like the idea of the s4s at the top of the window. That should give it a cleaner look if the gap is noticeable. I agree on not putting the picture rail into the window opening - I had phrased that part wrong.
I'm also trimming all my windows with casing. Should I skip this one since the crown molding is right there? I had considered trimming only the bottom half of the window with this setup.
shazapple 12-20-2012 03:32 PM
1 Attachment(s)
I'd cut the the bottom of the crown off so it fits the 3 1/8" space, and add blocking to fill the gap between the bottom of the crown and wall. Then I'd install 1x4 trim down the sides and bottom of the window. The trim would give the picture rail and the bottom portion of the crown something to end against.
Attachment 62301
BigJim 12-20-2012 07:29 PM
If you plan to put curtains up you could use the ceiling mold to make a valance and return the picture mold into the wall at the side trim. If you didn't want to do that you could use the 1X4 as suggested and wrap it with the ceiling mold, it would look good bumped out like that.
woodworkbykirk 12-20-2012 08:11 PM
if your planning on running the crown right through installing 5/4 stock as a header on the window trim is the only way to make it look proper. installing the crown to a picture framed window will look terrible plus you wont have a flat surface to nail the crown to along the wall
Jeff180 12-21-2012 08:17 AM
Is this right - nail up a header, wrap the header with crown, trim the window to the header?
The other windows in this room have blinds with a valance, so a valance here shouldn't look off. I don't plan on hanging curtains.
Jeff180 12-21-2012 08:18 AM
1 Attachment(s)
Forgot the picture
BigJim 12-21-2012 09:58 AM
Originally Posted by Jeff180 (Post 1077255)
Forgot the picture
This is what I was talking about. By the way, where is the header for that window? Is it built into the ceiling joists?
Jeff180 12-21-2012 03:24 PM
1 Attachment(s)
I think the window runs into the top plate of the wall. It's a pair of 2x4s.
Jeff180 07-07-2013 10:50 AM
2 Attachment(s)
Updating with finished pictures. I put a 1x4 across the top of the window, and ran the crown molding around it. We decided to skip the picture rail.
chitownken 07-07-2013 11:17 AM
Nice.
Willie T 07-07-2013 03:46 PM
Looks fine.
