Crown Molding-wavy Walls/ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-13-2006, 01:30 PM   #1
Rewards Points: 269
crown molding-wavy walls/ceiling
I am trying to install some crown molding in an old house with *very* wavy walls and ceilings. I am not able to get the molding to follow the curves in both the walls and ceiling. I was thinking that I would probably try to follow that wall as close as I could and while only hitting the low spots on the ceiling, thinking the gaps between the molding and ceiling would be less visible that those between the ceiling and the wall. Is there any accepted practice, or a trick I donít know? Short of steaming the molding, I donít know what else to do.
LanterDan is offline   Reply With Quote
Old 07-13-2006, 03:32 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Are you going to paint the molding or stain it?
- Build Well -
Old 07-13-2006, 03:56 PM   #3
Rewards Points: 269
stain. A big chunk of it is going across a recessed china cabinet that is stained, so I think it kind of has to match.
Old 07-13-2006, 09:38 PM   #4
Contractor
I take it that you are not using a cleat?
Teetorbilt is offline   Reply With Quote
Old 07-16-2006, 01:39 AM   #5
Rewards Points: 269
Sorry for the delay. Right now I’m just trying to test fit the piece; I haven’t yet thought about how the attach it. I don’t usually use a cleat, but I could. I still don’t think it solve the problem that if I force the molding the take the shape I want it to I’m pretty sure it will break. It’s a relatively thin pine molding, about 1.5” or so, and was flexible enough to deal with the waves in the rest of the house, but now I’m in an alcove type area that is much worse than the rest of the house.
Old 08-29-2006, 08:32 PM   #6
Rewards Points: 530
wavy walls
I have to wonder if part of the ceiling and wall can be skimmed to take some of the wave out.
Old 08-29-2006, 08:34 PM   #7
Rewards Points: 530
wavy walls
Hope this is not a double post. I wonder if thie wall and ceiling can be skimmed to remove some of the wavy areas.
Old 09-15-2006, 07:10 PM   #8
yoz
You need to find out why the ceiling is wavy.. Is there a sag in the dry wall, maybe you can put up some blocking and "lift" the dry wall. If the ceiling is on sliighly wave i have use dry wall counpound to fill in some of the voids.
yoz is offline   Reply With Quote
Painting crown molding greeniemom Painting 6 02-26-2008 03:26 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 08:13 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 02:34 PM
Crown Molding Ramblnmn Remodeling 3 10-24-2006 10:08 PM
