Crown Molding Transition Over Narrow Gap Between Ceiling And Window Top ... - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 08:39 PM   #1
Crown Molding Transition over narrow gap between ceiling and window top ...
I am trying to do crown molding in a living room which is 27'x15' and with 8' ceiling. The problem is two windows which are just about 2" from the ceiling - too close. Please see the picture attached.
I like to have the 4" molding considering the size of the room. But how do I transition over the windows without making it ugly? Any ideas are highly appreciated. Thanks much.
Crown Molding Transition over narrow gap between ceiling and window top ...-livingroom101.jpg
NallaChiruta is offline   Reply With Quote
Old 02-10-2010, 08:40 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Use really small crown molding or
before you hit the window, 90* the crown molding so it looks like it deadends into the wall.
I'm no carpenter, so someone else might chime in with some other ideas.
Journeyman Plumber
Old 02-11-2010, 01:39 AM   #3
Transition
You could try putting a arched cornice and than end the molding into that.[IMG]file:///C:/Users/Owner/AppData/Local/Temp/moz-screenshot.png[/IMG]Name:  b_arch_cornice.jpg
william duffer is offline   Reply With Quote
Old 02-11-2010, 02:04 AM   #4
Transition
There are many ways to make the cornice or buy one. If you make it like a box and than cut an arch out of the front to match the arch of the window it could look real nice. They are mainly made for hiding the curtain rod. You could put a valance up if you are not looking for full length curtains. Anyways just an idea. The room is looking great keep up the good work.
GARRYOWEN
Old 02-11-2010, 08:34 AM   #5
Crown Molding transition: use of Cornice
The cornice idea looks really promising. I am going to research a bit more in that area and move. Thanks much for the suggestion and the encouragement.
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 10:20 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
