Crown Molding Spring Angle - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 11:22 AM   #1
Do I need to factor in spring angle when mitering my crown? I am making my cuts without a bevel, just miters. I have a book with a chart showing spring angles with their corresponding miter and bevel angles...I am assuming this is only if cutting the crown while it's laying flat on the saw.
Thanks!
GJ
wannabehandson is offline   Reply With Quote
Old 04-25-2013, 11:45 AM   #2
Love for Construction
<*(((><'s Avatar
Thanks!
GJ
The spring angles only come into play if you want to cut the crown on the flat and use the bevel feature of the saw as well as the miter. If you are nesting the crown (using in the table and the fence to rest the molding at the angle) using the upside-down and backwards technique you only need to concern yourself with the miter adjustment.
Think about it this way the two flat spots of the crown that rest against the wall and the ceiling being nested against the table and fence of the saw take the spring angle out of the equation when cutting it.
-luke-
<*(((>< is offline   Reply With Quote
The Following User Says Thank You to <*(((>< For This Useful Post:
wannabehandson (04-25-2013)
Old 04-25-2013, 12:07 PM   #3
That's what I figured. The book I have makes a bolded note to understand which spring angle you have while failing to mention this only pertains to flat cuts. Perhaps I just should have known better...thanks for the reply!
Crown molding inside bay window Dieter Carpentry 7 10-03-2010 06:23 PM
Crown molding with uneven ceilings, Help FLARob Remodeling 2 09-30-2010 12:37 PM
Crown molding to arched window tas10000 Carpentry 5 09-17-2010 03:35 PM
Can't find instr. on cutting 135 degree inside angle in crown molding Hossenfeffer Carpentry 8 05-27-2010 07:25 PM
making own crown molding marin001 Carpentry 7 03-28-2010 11:08 PM
