Crown Molding On Rounded Corners - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-26-2010, 09:23 PM   #1
Crown molding on rounded corners
I have been trying to install 7 1/4 crown molding on a rounded corner today and I have been haveing a hard time figureing out the bevel and miter numbers. The crown is to large to nest against the fence so I am laying it flat on the table. It is a 90 degree corner but the corner bead is rounded, not your normal square bead. I have been able to do all the inside corners no problem and they fit great but the outside corners are giving me trouble. The spring abngle as far as I have been able to tell is 31 degrees. If any one has any tips or even possibly the numbers needed would be great. Thanks
Confused Carpenter
MarcoM1022 is offline   Reply With Quote
Old 05-27-2010, 07:33 AM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
I've used 22 1/2 utilizng 4 pieces to make the turn (2 being on the actual rounded corner).
Man of many hats
wrangler is offline   Reply With Quote
Old 05-29-2010, 01:20 PM   #3
Jay123's Avatar
Here's a pic/explanation.
http://www.ehow.com/how_4672250_inst...d-corners.html
Jay123 is offline   Reply With Quote
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Coping Crown Molding in So Cal Klawman Carpentry 32 12-23-2009 03:51 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
measuring inside corners for crown molding peciousroy Carpentry 13 08-04-2008 06:39 AM
