Crown Molding Lighting? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2007, 12:51 AM   #1
Rewards Points: 150
crown molding lighting?
geez a picture is really worth a thousand words....
so what's the easiest way to achieve the above results in a typical "square box" room... I guess framing out along the top of the walls to simulate a recessed ceiling? I haven't done my homework yet but am just looking for a kick-in-the-butt to get me pointed in the right direction.
elementx440 is offline   Reply With Quote
Old 02-02-2007, 09:02 AM   #2
Easy http://www.invitinghome.com/Indirect...ght_List_A.htm
or you can use regular crown and rope lights, In that case you will need to cut blocks out of 2"x2" with an angle to match the crown and place them at each stud. 45 the corners since the top of the molding isn't supported. You will need a power source so you may need an electrician.
shawnplr is offline   Reply With Quote
Crown Molding joe3534 Carpentry 9 06-23-2008 11:15 AM
Painting crown molding greeniemom Painting 6 02-26-2008 03:26 PM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 08:13 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 02:34 PM
Crown Molding Ramblnmn Remodeling 3 10-24-2006 10:08 PM
