Crown Molding Install Question - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 10:57 AM   #31
Old School
Willie T's Avatar
I run a heavy bead of Polyseamseal Adhesive behind all my corners and down the trough between the back of the crown and the cabinet. Where it butts into the walls too.
The best glue I've found for crown is a CA type glue. "2P-10" by Fast Cap is a great one. I use the Jel.
Willie T
Old 01-14-2012, 11:11 AM   #32
firehawkmph's Avatar
Rewards Points: 1,800
Originally Posted by petros151 View Post
I'll hunt one of these down and give it a shot.
I had another thought though what if get some hot glue into the back side of the joint and hold it? It will set in 30 sec
does anyone ever use hot glue like that?
I"ll experiment on a scrap piece joint and see if it looks like it will hold.
Thanks!
Pet,
I have used hot glue on the joints. But it wasn't the craft type gun, it was one of these:
http://www.woodcraft.com/Product/200...e-Gun-Kit.aspx
I have glued 3 or 4 pieces at a time, then lifted it place and fastened it. You have to be careful handling the assembly once its glued.
These are the clamps I use. Made in Germany. Pretty good setup.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
petros151 (01-14-2012)
Tags
crown , kitchen cabinet , molding
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Crown Molding to ceiling gap question? Zerosignal Carpentry 12 01-27-2011 06:52 PM
Cabinet Crown Molding highchile Carpentry 1 02-24-2010 04:49 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 10:58 AM
