Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-04-2009, 11:52 AM   #1
Crown molding inside bay window
Hey everyone!
I'm having a problem figuring out a solution that is both practical and visually appealing. I’m hanging 3 ¾” crown that’s available at the local big box store in a bay window. I’m set on the miter saw angles, but the inside corners of the bay are rounded over instead of nice, sharp corners like in 90 deg. walls. The angle to try and cope the back of the crown seems almost prohibitive to try and do that. I’ve tried a test piece where I use biscuits and glue on the butt ends, but there is too much of a gap under the crown where it meets the wall. Has anyone done an inside corner similar to an outside bullnose corner? I thought about applying taping compound under the crown, however the walls is a darker color and the difference between the crown and wall would be magnified. Ideas?
Thanks in advance.
Dieter is offline   Reply With Quote
Old 05-04-2009, 01:09 PM   #2
Send a message via AIM to Bocolo
If I understand correctly what you are asking look at this thread Crown moulding: Flat ceiling to angled wall question. from a couple of days ago.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 05-04-2009, 03:05 PM   #3
No, I have a bay window. The angles of the window are 135 deg. The ceiling is flat. The corners where the sections of the bay meet are rounded. I want to see if there is a fix for the gap where the crown's bottom edge (pointed) meets the rounded corner. Similar to a inside bullnose.
Old 05-04-2009, 05:51 PM   #4
Newbie Bill
Hi Dieter,
I don't have an answer for you but am wondering if you will need to do something similar to what was done on these outside corner trim pieces. But done on an inside corner.
drtbk4ever is offline   Reply With Quote
Old 05-05-2009, 08:22 AM   #5
Yes, that's what I'm looking for. Inside corner, bullnose for crown. Or a good looking alternative.
Thanks.
Old 10-03-2010, 05:12 PM   #6
Thanks.
Hello, I'm in the same situation, I have a bay window with rounded inside corners and trying to find a solution for my 4 1/4" crown moulding. I thought of trying the bullnose method, but haven't gotten around to it yet.
Did you find a solution?
Steve
stevecornick is offline   Reply With Quote
Old 10-03-2010, 06:42 PM   #7
uva uvam videndo variafit
WirelessG's Avatar
had an idea, but it won't work
WirelessG is offline   Reply With Quote
Old 10-03-2010, 07:23 PM   #8
PHB Construction LLC
Paulie's Avatar
Try laying flat stock down first and make the flat stock fit the round corner. Now you have a nice sharp corner to work with.
By flat stock I mean 1/2" X 4" or something of the like.
Just saw the original post was in May or something, hopefully the OP figured it out by now.
Paulie is offline   Reply With Quote
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
measuring inside corners for crown molding peciousroy Carpentry 13 08-04-2008 06:39 AM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
