Crown Molding Finish Problem - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-05-2007, 10:53 AM   #1
Crown molding finish problem
Just had crown molding installed "professionally". Is the putty supposed to be sanded off before we paint? Seems as if everywhere the installer puttied, my paint isn't sticking, or the putty is getting nasty lines in it, and showing through. The molding was pre-primed, and we've already got 2 coats of glossy white on - but it looks really blotchy!
Do we need to go back and sand all the blotchy areas (probably 130 feet of installed crown molding!) or is there some way to fix this?
Help!
lewlewjones is offline   Reply With Quote
Old 05-05-2007, 02:04 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Help!
Is it putty, or did he use some kind of silicone based product, like white silicone caulking?
Paint will not stick to silicone. What you describe is what happens when you try to paint over silicone.
- Build Well -
Old 05-05-2007, 07:13 PM   #3
zel
Rewards Points: 150
Send a message via AIM to zel
you could try primer first before the paint.
zel is offline   Reply With Quote
Crown Molding joe3534 Carpentry 9 06-23-2008 10:15 AM
Painting crown molding greeniemom Painting 6 02-26-2008 02:26 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 01:34 PM
Crown Molding Ramblnmn Remodeling 3 10-24-2006 09:08 PM
