Crown Molding And Ceramic Tile - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 07:36 PM   #1
Rewards Points: 119
Crown molding and ceramic tile
I was thinking of putting crown molding around a bathroom ceiling where the ceramic tile goes all the way up to the ceiling.
What would be the best way to assure attachment to the tiles at the bottom of the crown molding.
RH913RH is offline   Reply With Quote
Old 08-28-2012, 10:27 PM   #2
attach cleats cut from 2/4's up in the corner with screws through holes drilled in the tile. you can angle the side of the cleat to match the angle of the crown. make sure that the crown is 1/2 inch away from them so you don't have the crown hitting them before it touches the wall or ceiling in other words you want a little gap between the crown and the cleats. you would need these on the walls that where the crown runs parallel with the ceiling joists anyway unless it's smaller crown. it would look something like this viewed from the end and sized to fit behind your crown molding
Old 08-29-2012, 06:58 AM   #3
Rewards Points: 119
Thanks for the quick suggestion.
New Ceramic Tile, with a Curved Edge??? Single Malt Flooring 13 08-25-2012 09:27 AM
how do I attach ceramic tile to ceramic tile? porchhen9 Remodeling 8 07-31-2011 02:59 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Joining carpet and ceramic tile rooms TedT Flooring 10 05-21-2008 08:25 PM
