Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-30-2009, 08:48 AM   #16
Crown molding on with catherderal celing for LED lights
Other half? Other 1/10th. Very Nice. But when you do not turn on the cans, how much light is in the room? Can you see enough to walk around and not crash into things?
My_attempt is offline   Reply With Quote
Old 01-30-2009, 08:52 AM   #17
Jay123's Avatar
It's been a few years since these installs, but yeah, they give off a little light in a dark room...I wouldn't want to perform brain surgery with the rope lighting alone...but, they're more for ambiance than anything else.
J
Jay123 is offline   Reply With Quote
Old 01-30-2009, 09:03 AM   #18
Thanks everyone.... I will see how a few of these options look and work for us.
Old 07-22-2009, 02:34 AM   #19
Originally Posted by Jay123 View Post
Here's a few shots of some crown dropped down for rope lighting...sorry the last one is without the lights, but as you can see the top of the crown is only 2-3 inches from the ceiling for a nice lighting effect...
I was thinking about doing this in my home. what is the minimum i should come down from the ceiling to install the crown molding to give the right effect. I don't have cathedral ceilings or anything, so i am going to have to go with the minimum here.
-thanks
SilverTouch is offline   Reply With Quote
Old 07-22-2009, 06:59 AM   #20
Jay123's Avatar
I've install the crown where the top of the crown is down 2 inches from the ceiling.
Old 07-22-2009, 11:52 AM   #21
Xtreme DIY'r
Keeping mind that LED lighting is directional, 30-60 degree light
Rope lighting using normal minis will produce over all light in every direction
Rope light will produce heat, DO NOT coil it or light it up when it is coiled
If the LED in the rope light is pointing "the wrong way" then you will have less light coming out in the direction you want
I have 18' of LED rope light in my kitchen (to be remodeled) as a test
It is very noticeable the directional nature of the LED light
My rope light is fully exposed under the cabinets at present
The 18' length uses a total of 10w while on
Normal rope light will use around 3w per foot depending upon lights used
You can "line-up" the LEDs in the rope light to point in the direction you want
Provided they are all installed in the rope light pointing in the same direction
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Crown Molding in the Kitchen Woody730 Remodeling 8 05-21-2008 07:17 AM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 10:58 AM
Crown Molding: Lay flat or stand upside-down dtmbizzle Carpentry 15 09-27-2007 12:33 AM
