Crown Molding On Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 09:24 PM   #1
Crown Molding on Cabinets
How would I go about cutting crown molding like this? I need the angles. I have a compound miter saw. I realize you typically stagger and change depth but for my existing cabinets that would cause a lot of problems. I need it for a staggered cabinet that is flush.
Thanks!!!
Kjm25bball is offline   Reply With Quote
Old 05-12-2012, 10:01 PM   #2
Rewards Points: 13,450
http://www.amazon.com/Starrett-505A-.../dp/B000B8N0SU
Old 05-12-2012, 10:44 PM   #3
I only have to do two cabinets. I don't really want to spend $50 on a tool.
Old 05-13-2012, 02:57 AM   #4
Too Short? Cut it Again!
I cannot remember if they were cheap or free but I ran across some promising looking Android apps for miter angle computations. There is probably a free online application.
Old 05-13-2012, 07:35 AM   #5
Retired
Edgar214's Avatar
Here a smaller cheaper model Starrett.
http://www.amazon.com/Starrett-505P-...ref=pd_cp_hi_0
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 05-13-2012, 11:27 AM   #6
Rewards Points: 636
well there are different spring angles crown can be so it depends on that to use a compound bevel cut. i have seen this done by a cabinet installer we use a few times looked scary to me and not the way i cut crown but it worked and fit good surprisingly. he just held the crown against fence just the same way is was going up on cabinets with saw on beveled angle he wanted held it firm and cut it.
to find bevel needed for top cabinet it should be 22.5 at least that is normally what they are. take any small scrap of wood cut the angles hold them up against side and face of cabinet and see if it is correct
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-13-2012, 07:34 PM   #7
firehawkmph's Avatar
Rewards Points: 1,864
If you're using prefinished molding from a cabinet company, the $50 for the protractor might end up being cheap if you scrap a couple lenghts of the molding. I have one of the starret protractors. Excellent tool.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
Now the fun part! Crown molding on cabinets round II petros151 Carpentry 21 01-19-2012 02:44 PM
How to handle crown molding transition to kitchen cabinets mystic_cobra Carpentry 6 09-15-2011 02:37 PM
Crown Molding on cabinets ducky910 General DIY Discussions 10 08-08-2011 07:26 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
