Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-17-2012, 06:32 PM   #31
Crown molding angle question
Of course thats assuming you got the right angle you need. Hope that helps.
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 09:41 PM   #32
Lavid2002's Avatar
I got it!
I just use this website
http://www.sbebuilders.com/cgi-bin/g...pring_Angle=38
Plug in the angle of my crown, and use their angles. Most of my triangles require acute angles less than 50*
These angles require cuts of 55* or so on my saw, and it only goes up to 47~48
I simply made a block cut at precisely 10* and adjust the angle on the saw accordingly. E.g. if my angle is 55* I put the block down and set the saw to 45* and slice!
Whoever said "Those long cuts pull the crown" is right! Especially with my fingers so close to the saw these are dangerous cuts.
here are a few pictures. I hope I don't run out of bevel settings as that would be a huge PITA
Thanks everyone! If I run into any more problems I will post here. Please ignore the blue painters taped HVAC vent...
-Dave
Lavid2002 is offline   Reply With Quote
Old 08-17-2012, 09:43 PM   #33
If my advise helped you hit "Thanks"
The Following User Says Thank You to Hammer450R For This Useful Post:
shadytrake (08-22-2012)
Old 08-22-2012, 07:48 PM   #34
shadytrake's Avatar
Looks awesome!
Here's my project...come on over.
shadytrake is offline   Reply With Quote
Old 08-23-2012, 10:24 PM   #35
Lavid2002's Avatar
Thanks mayng! :D I am really happy with how it's coming out
I am really happy with the outcome. I wish I had a ton of time and patience so I could make all the angles look perfect but I simply don't have the attributes above. School starts up again on the 5th.
All thats left is some filler for the holes, some floor trim, and some touch up paint.
I only have 4 small triangles left in the room!
Old 08-24-2012, 07:05 AM   #36
Congrats almost done!!! Also great idea on the angle block to get more angle out of the saw...hehe
crown molding and chair rails hollyjo213 Kitchen & Bath Remodeling 2 10-02-2009 01:56 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
crown molding ponch37300 Carpentry 15 06-05-2009 03:35 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 02:16 PM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 10:58 AM
