Crown Molding Angle Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 07:31 PM   #1
Lavid2002's Avatar
Rewards Points: 85
Crown molding angle question
Hey guys, I am finally around to the part of my project where I hang crown molding, problem is...I've never done it before
I have read a bunch of tutorials and watched a bunch of videos, I have made a few cuts and I can't get my angles right. I am using a tool to measure the inside angle, since I am dealing with a bunch of different angles, and I am using a block of wood to keep the crown at the proper orientation and upside down on the miter.
Can someone tell me what I'm doing wrong?
Here's a pictures of the triangle shaped area I am trying to crown, and here's the corresponding angles I measured (They sum to 180 so my measuring tool and I must be close) When I tried to cut the 50* corner I cut the left side crown to 25* and the right side of the crown to 25* and together they should make 50* (My thought process, if 45*+45* makes 90 right?) nope! The two together gives me apx 130*...roughly. So my thought process is as follows, 180-50 is 130*. Do I need need to use a formula like the following? (I just made this up...it makes sense in theory to me)
(Angle measured - 180)/2 = Angle to cut for each side of the crown.
Also, if this is the formula I should be using...how in the heck can I cut these angles? Lets use my 50* angle example. 130/2 = 65*. My miter only goes 45* in each direction, and 45* on a bevel. I don't know carpentry very well but on an XYZ coordinate plane that's a variation of 45* on the XY plane, and a variance in 1 direction on the YZ plane.
Here's some pix of my setup. Point me in the right direction!
-Dave
Lavid2002 is offline   Reply With Quote
Old 07-07-2012, 08:30 PM   #2
DIY staff
Rewards Points: 7,174
If the picture of the cut in the miter saw is for your ceiling --
I'm confused-
that is an outside corner cut---
an inside corner cut would be longer at the top and narrower at the bottom.
What is going on in that photo?
Old 07-07-2012, 08:56 PM   #3
Lavid2002's Avatar
Rewards Points: 85
I'm confused-
Ignore the photo, the crown has flipped and is showing the non-presentation side I was snapping pix so quickly I forgot to flip it
Lol
-Dave
Old 07-07-2012, 10:20 PM   #4
firehawkmph's Avatar
Rewards Points: 1,798
Inside corner cuts are cut upside down but not backwards. So a right angle would be cut on the right side of the blade. If you were cutting outside miters, your notations on your board would be correct. I would recommend making an L shaped bed for your miter box and screw it to your fence from behind with short screws. Then fasten a small piece of wood to the base of it for your stop to hold the molding at the correct orientation. It gets the clamps out of your way and makes sure your stop doesn't move.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 07-07-2012, 10:43 PM   #5
Rewards Points: 1,426
You sure you're putting it upside down and backwards? I just did crown for the first time recently and banged through it with no problems. My corners were all pretty close to 90 degrees, but the idea transfers to any angle.
mikegp is offline   Reply With Quote
Old 07-07-2012, 11:36 PM   #6
Lavid2002's Avatar
Rewards Points: 85
Mike Hawkins
Let me give this a shot tomorrow and see how it works
Thanks! I will build a box if the clamps give me any trouble at all.
There was no constructive part of this comment.
Old 07-08-2012, 01:13 PM   #7
Lavid2002's Avatar
Rewards Points: 85
Nope, I tried to cut the left side of the piece from the left side of the saw. When I put it into place the crown is upside down. Are you suggesting I cut the crown right side up in the saw? That would allow me to cut it on the left side for the left piece...
I can make a video of what I'm doing if it would help you guys understand what I'm doing.
-Dave
Old 07-08-2012, 04:43 PM   #8
Upside down and backwards is correct. Though it wasn't constructive last time I said it.
Old 07-08-2012, 04:51 PM   #9
DIY staff
You have chosen a most difficult miter for your first crown project.
As you have 2 out of three corners that are to tight to make on your chop saw without
making a L-shaped cradle for the trim that can be clamped or fastened to the saw.
Your saw s maximum cut is 45* or so---those tight corners will require adding a wedge behind
the L-shaped cradle to achieve the numbers needed.
Old 07-08-2012, 05:24 PM   #10
Lavid2002's Avatar
Rewards Points: 85
Right! This makes perfect sense! I will make a box tonight, and cut a board to 25* to wedge the box to.
So I am on the right track?? In theory, if I had a saw that could cut steeper angles this would be a piece 0-cake but I need to improvise right?
Thanks Mike
Old 07-08-2012, 05:38 PM   #11
Just wanted to let you know, if for some reason you're not already aware, the guy (or company) who makes your angle finder has a website at http://www.compoundmiter.com/true_angle_tool.html. It's possible there's more info and/or tools from them that could help you out.
pucks101 is offline   Reply With Quote
Old 07-08-2012, 05:42 PM   #12
DIY staff
Right---try this for making your test cuts---take the angle with your adjustable angle tool--
use that to cut a sheet of paper to match---
Fold that paper in half--
That is your miter angle.
Use that to set the saw--make two test blocks--
Adjust the cut for a perfect fit--use that number for left and right cuts--
You sure jumped in with both feet--good luck--those long miters really pull the board-
So support every thing well--make sure your hands are safe and
don't get pulled into the saw if the blade grabs the work on a long miter.
mae-ling (07-08-2012)
Old 07-22-2012, 11:19 AM   #13
DIY staff
How about an update?
Tough first job---
Old 07-26-2012, 12:17 PM   #14
Hope you have already figured out your problem! If you have not, take a look at our site http://cutncrown.com and with our jig you can call us with any specific questions on your project, our phone number is right on top of our website. Our jig makes everything simple with a quick three step process, takes minutes to learn and eliminates the entire upside down and backwards thought process. With our video showing how to cut and install crown molding, it makes our system a quick and easy way to successfully finish your project. We also have other videos on youtube that can help with more complicated cuts: http://www.youtube.com/playlist?list...0&feature=plcp
No matter what you decide on, good luck to you on the project!
cutncrown is offline   Reply With Quote
Old 07-26-2012, 03:38 PM   #15
for the angle you show the cut would need to be 65(180-50=130 divided by 2 = 6). the 25 would work if you had an angle of 50 from straight. your angle is 130 from straight.
The Following User Says Thank You to DannyT For This Useful Post:
<*(((>< (07-26-2012)
crown molding and chair rails hollyjo213 Kitchen & Bath Remodeling 2 10-02-2009 01:56 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
crown molding ponch37300 Carpentry 15 06-05-2009 03:35 PM
ceiling white - crown molding color question remodelingagain Interior Decorating 3 06-06-2008 02:16 PM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 10:58 AM
