Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 09:58 PM   #1
crown molding
We have a 19' ceiling in the living room and the previous owners installed a horizontal shelving along the seam where the upper and lower sheetrock joins together to cover the seam. We remodeled recently and removed the shelving. What kind of wide molding can we install to cover up the seam ,covering approximately 12" of space, or what kind of multiple moldings stacked can we use? Thanks a million
sandy patterson is offline   Reply With Quote
Old 09-13-2010, 06:59 AM   #2
Your dimension shows up on my computer as 12&quot, not sure what that is, but if it is a large space, you can use combinations of flat stock and trim. It is limited by imagination. but lumberyards and even big box carry a large variety of stock trim moldings, ranging from simple to baroque. A small space could be covered by a simple chair rail molding.
Old 09-13-2010, 01:30 PM   #3
Old School
Willie T's Avatar
This happens quite a lot. Generally " means ( " ) .... double quotes or the inch mark.
Willie T
Old 09-13-2010, 07:43 PM   #4
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
Depending on how bad/wide the seam is, you can use 2" chair rail. If you want to float the seam a little, you can use a combination of moldings and simply gloss the drywall in between.
I have 20' ceilings and I went with 7" crown with 5" baseboard turned upside down and protruding from the bottom of the crown, then 6 or 8 inches of gloss drywall and 2" rail. The whole things measures 16" or so. If I understand your situation, you seam is about halfway up the wall, so the size of what I have would be too much in your case. However, you may be able to do something similar and save on the molding. As I said before, however, you;ll have to float the drywall to gloss it, which would be, to some extent, contrary to covering it with molding.
Meriwether Lewis used to note "&c" (or maybe it was &ct) in his journals describing his voage, which is an old way of saying "etc".
WirelessG is offline   Reply With Quote
Old 09-13-2010, 08:32 PM   #5
It also usually means they are copying the post from one site to another
Posting on as many sites as possible to get a response
Old 09-13-2010, 09:46 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 194
This trim is on a 14 foot ceiling. Just a thought.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-14-2010, 07:13 PM   #7
WirelessG's Avatar
Rewards Points: 698
That's some detailed looking trim there.
The Following User Says Thank You to WirelessG For This Useful Post:
BigJim (09-14-2010)
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
making own crown molding marin001 Carpentry 7 03-29-2010 12:08 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
