Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 11:22 AM   #1
Joe-J
Crown Molding
I'm sure this has been asked many times, so please excuse me if this is a very old subject. I'm new to this forum.
I am installing crown molding. I know that the proper setting for my rip saw for a 90 degree angle is Miter 31.62 degrees and bevel 33.85 degrees for the molding i am using. What is the proper setting for 45 degrees? Is it 1/2 of 31.62/33.85 degrees? That seems almost too simple.
Joe
Joe-J is offline   Reply With Quote
Old 05-04-2009, 01:23 PM   #2
Old School
Willie T's Avatar
First off, why are you using a rip saw on your crown?
Willie T
Old 05-04-2009, 02:19 PM   #3
Joe-J
I may be using an incorrect term. I plan on using a double bevel compound miter saw.
From what i have seen it may be best just to use a crown molding stop on the base and forget about cutting it lying flat on the base of the saw.
Thanks,
Joe
Old 05-04-2009, 05:57 PM   #4
Old School
Willie T's Avatar
Thanks,
Joe
Just messin' with ya, Joe. Yes, you're right about not having to bother with the compound bevels in the "flat" method. Few pros do anything but the "bedded", upsidedown and backward method. (The way you described it with the base stop)
Willie T
Old 05-04-2009, 06:00 PM   #5
Joe-J
Thanks, I think I've got it now!
Old 05-04-2009, 06:10 PM   #6
Old School
Willie T's Avatar
Here's how that upsidedown thing works....... cutting crown molding for cope cuts
Willie T
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 08:32 AM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 01:49 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 09:58 AM
