Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 06:01 PM   #1
Crown Molding
I have a corner cabinet that has a degree os 67.5 which is half of the 135 degree that is showing on the degree device. The miter saw only goes to 45 degrees. Ahat am I doing wrong or is there another way tomeasure this? I have firgured out the reat of the crown molding for the other cabinets but this one has given fits. Please help.
Boyd
Boyd Adams is offline   Reply With Quote
Old 04-20-2012, 06:50 PM   #2
Haverhill Trade 1965
My guess is the degree device is reading the opposite angle. Try deducting 90 degrees from 135 = 40. It may be 40 or 20 degrees, but even that is an odd degree. Can you describe the cabinet more? is it a non standard corner or a custom cabinet of some kind?
Duckweather is offline   Reply With Quote
Old 04-21-2012, 07:19 AM   #3
Cabinet
It is a Upper corner cabinet and I will see if I can send a picture. Can not seend picture but the cabinet is your usual corner cabinet. Just needed the correct thing to do when installing the crown molding. Have not done but 45 degree and this one I did not want to cut nothing until got some info. I will use some scrap peices and see if the measurment will work. Thanks
Old 04-21-2012, 10:50 AM   #4
I think the 135 degrees is 180 - 135 leaving 45 degrees. The cut should be 1/2 of that or 22 1/2 degrees. your tool is giving the opposite side of the angleof 45 degrees.
Old 04-21-2012, 10:58 AM   #5
Rewards Points: 13,712
One of these will make the job real simple when figuring out angles.
http://www.amazon.com/Starrett-505A-.../dp/B000B8N0SU
Old 04-21-2012, 02:35 PM   #6
DIY staff
Rewards Points: 7,174
You guys with all those numbers---Fold a peice of paper to fit the inside of the corner--that is your angle.
Next--fold the paper in half---that the miter angle---
For out side corners --tape two peices of paper together--then fold at the juncture--
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
christie5683 (06-08-2012), user1007 (04-24-2012)
Old 04-21-2012, 03:30 PM   #7
Good instruction...sounds like you've done it a time or two
creeper is offline   Reply With Quote
Old 04-21-2012, 03:58 PM   #8
DIY staff
I have tried every sort of fancy gadget for finding angles---none works any better than a well folded sheet of paper---
I have a simple mind ---so I like simple solutions--
Old 04-21-2012, 04:04 PM   #9
No offence intended to you, but lots of people can be brilliant at what they do..craftsman, mechanic ect. but then be a little slow on the uptake in other areas
Old 04-21-2012, 04:55 PM   #10
Rewards Points: 1,470
I presume this is what you mean?
Corner cabinet outside angle is 22.5 on the front.
ktkelly is offline   Reply With Quote
Old 04-22-2012, 05:55 AM   #11
Thanks to everyone for the replys. Will give the 22.5 degree a shot by cutting some scrap wood. Again, thanks for the info.
Boyd
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
making own crown molding marin001 Carpentry 7 03-28-2010 11:08 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
