Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-12-2011, 08:54 PM   #1
Crown Molding 135 degree interior angle
Hello,
I am down to my last corner of a room for crown molding and it's my toughest corner. It's a 135 degree interior angle. The spring angle is 45 degrees.
I have a miter saw that can make bevel cuts. I have looked around the internet and it seems that I should be setting my saw at:
16.32 for the miter
15.7 for the bevel
but when I do that, the pieces don't seem to fit properly. Is there something I am missing? The calculators also saw it should be "From level 74.3" but I have no idea what that means. All my other corners were 90 degree interior cuts and I had no problem doing them.
Any help is greatly appreciated.
Thanks,
Mike
mtcnd2002 is offline   Reply With Quote
Old 02-12-2011, 11:06 PM   #2
Old School
Willie T's Avatar
Have you tried a 'cope cut' instead of direct bevels? It might be easier to fit on such a shallow inside corner.
Willie T
Willie T is online now   Reply With Quote
Old 02-13-2011, 09:28 PM   #3
Stairguy
its 22-1/2 degrees
135-90=45
45 divided by 2 = 22.5 degrees
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
Willie T (02-13-2011)
Old 02-13-2011, 10:24 PM   #4
Old School
Willie T's Avatar
Miller is correct if you are cutting your crown 'nested'. But if you are cutting 'lying flat', you will need to use the numbers you found on your chart online.
I would still suggest trying to cope the mate if your equal angles aren't working out.
Willie T
Old 02-14-2011, 08:00 AM   #5
Originally Posted by Willie T View Post
Miller is correct if you are cutting your crown 'nested'. .
Then cut it nested
mrgins is offline   Reply With Quote
Old 02-14-2011, 07:12 PM   #6
Old School
Willie T's Avatar
Originally Posted by mrgins View Post
Then cut it nested
Uh, this IS a DIY forum, and some people either may not know how to 'nest' crown, or their saw may not handle their specific crown size in a nested position.
Willie T
Old 02-14-2011, 07:46 PM   #7
I understand its a DIY forum, Willie, but if they're talking about buying/renting a chop saw to cut a compound flat, then it's easier to cut it nested in my opinion. Each to their own, thats why I enjoy reading all the varying opinions and methods posted here.
Old 02-19-2011, 01:46 AM   #8
miller is right half of 45 is 22,5 also coping can solve this
jack of trades is offline   Reply With Quote
Old 02-19-2011, 02:37 AM   #9
another vote for coping it.
1910NE is offline   Reply With Quote
Can't find instr. on cutting 135 degree inside angle in crown molding Hossenfeffer Carpentry 8 05-27-2010 08:25 PM
making own crown molding marin001 Carpentry 7 03-29-2010 12:08 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
