-   -   Crown Molding 135 degree interior angle (http://www.diychatroom.com/f14/crown-molding-135-degree-interior-angle-95305/)
mtcnd2002 02-12-2011 08:54 PM
Hello,
I am down to my last corner of a room for crown molding and it's my toughest corner. It's a 135 degree interior angle. The spring angle is 45 degrees.
I have a miter saw that can make bevel cuts. I have looked around the internet and it seems that I should be setting my saw at:
16.32 for the miter
15.7 for the bevel
but when I do that, the pieces don't seem to fit properly. Is there something I am missing? The calculators also saw it should be "From level 74.3" but I have no idea what that means. All my other corners were 90 degree interior cuts and I had no problem doing them.
Any help is greatly appreciated.
Thanks,
Mike
Willie T 02-12-2011 11:06 PM
Have you tried a 'cope cut' instead of direct bevels? It might be easier to fit on such a shallow inside corner.
Millertyme 02-13-2011 09:28 PM
its 22-1/2 degrees
135-90=45
45 divided by 2 = 22.5 degrees
Willie T 02-13-2011 10:24 PM
Miller is correct if you are cutting your crown 'nested'. But if you are cutting 'lying flat', you will need to use the numbers you found on your chart online.
I would still suggest trying to cope the mate if your equal angles aren't working out.
mrgins 02-14-2011 08:00 AM
Originally Posted by Willie T (Post 590719)
Miller is correct if you are cutting your crown 'nested'. .
Then cut it nested
Willie T 02-14-2011 07:12 PM
Originally Posted by mrgins (Post 590869)
Then cut it nested
Uh, this IS a DIY forum, and some people either may not know how to 'nest' crown, or their saw may not handle their specific crown size in a nested position.
mrgins 02-14-2011 07:46 PM
I understand its a DIY forum, Willie, but if they're talking about buying/renting a chop saw to cut a compound flat, then it's easier to cut it nested in my opinion. Each to their own, thats why I enjoy reading all the varying opinions and methods posted here.
jack of trades 02-19-2011 01:46 AM
jack of trades
miller is right half of 45 is 22,5 also coping can solve this
1910NE 02-19-2011 02:37 AM
another vote for coping it.
