Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 08:22 PM   #1
crown molding
I want to make a piture frame with the final look of crown moulding. I have the crown moulding tools for my grizzly shaper but I don't know just what to do?
toby598 is offline   Reply With Quote
Old 02-04-2012, 08:26 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Ok... Let me see here.
Wait. I'll beer right back.
titanoman is offline   Reply With Quote
Old 02-04-2012, 09:07 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Do you have any pictures of your cutters or the type they are, there is no way anyone can help with the info you have given.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-04-2012, 09:54 PM   #4
Rewards Points: 77
The crown molding cutter makes a nice face profile, but you have to re-think the edges. If you are going to make the frame with the top of the crown tight to the wall, you have to figure for a step for the picture bihind the inside edge. If the crown sticks out into the room ahead of the picture, you need to figure out a different pocket for the picture so from the side the frame looks finished. I use a chair-rail profile with a 3/4" x 2 1/2" piece behind it. This piece is offset to the outside about 5/8". I route a classical edge on that piece. I actually make the flat back frame first about 1/4" bigger than my picture. I route around the outside edge, then cut the chair rail to fit on top. I glue and pin nail this layer on. This method makes beautiful frames, painted or stained.
MNsawyergp is offline   Reply With Quote
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 05:20 PM
making own crown molding marin001 Carpentry 7 03-28-2010 11:08 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 12:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
