Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 04:03 PM   #1
Rewards Points: 109
Crown molding
I have no Idea what type of ceiling I have.. I have searched vaulted, tray, and a few others but I have yet to see the same type of ceiling as mine.. My question is how do I add crown molding to this type of ceiling..
I have attached a photo of my ceilings.. Thanks for the help
mchipser is offline   Reply With Quote
Old 09-08-2011, 05:40 PM   #2
This is a personal opinion....you can't add crown mold to that room and have it look right.
1910NE is offline   Reply With Quote
Old 09-08-2011, 05:53 PM   #3
That I would say is a type of tray ceiling, least wise in Fulton County.
The only way I have seen crown installed in that set-up is to install it on first angle and hold it down so that it does not contact the angle or flare. Similar to installs where a light is laid behind crown to illuminate up. You would have to put a nailer on the wall before installing it to provide sufficiant nailing.
framingrailman is offline   Reply With Quote
Old 09-08-2011, 06:24 PM   #4
Inspector called ours a "coffered ceiling".
CluelessInKs is offline   Reply With Quote
Old 09-08-2011, 08:21 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
It is a coffered ceiling. All four walls angle in at the top.
Mike Hawins
firehawkmph is offline   Reply With Quote
Old 09-08-2011, 09:21 PM   #6
Rewards Points: 109
Everything I am finding about coffered ceilings are with exposed beams
Old 09-09-2011, 12:54 PM   #7
Doesn't have to have beams MC, coffered refers to the shape. Have to agree with previous poster, crown molding could be done, but not in the traditional sense. Not sure it would look right.
Mike Hawkins
Old 09-09-2011, 10:24 PM   #8
Another option would be to use tongue and groove, or bead board on the coffered ceiling, from the point where the vertical wall plane meets the diagonal ceiling. You could then add a trim detail to finish it off. Not exactly what you were aiming for, and probably more expensive...
Old 09-10-2011, 08:19 AM   #9
KemoSabe
loneframer's Avatar
IME, a coffered ceiling is divided into segments and typically wrapped with wood or composite trim. In this area, yours is referred to as a tray ceiling.
Here is an example of what we refer to as a coffered ceiling.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 09-10-2011, 08:28 AM   #10
now thats a coffered ceiling!
Old 09-10-2011, 08:44 AM   #11
Old School
Willie T's Avatar
A "coffer" is descriptive of a box... often referring to a box money is kept in. Decorative ceilings 'boxed' in are called coffered ceilings. Most often they have a series of boxes in the ceiling.
What you have is known as a 'tray' ceiling because it resembles an inverted tray as you look up at it... Tray ceilings don't typically have any divisions within their structures as coffered ceilings usually do.
Willie T
Old 09-10-2011, 10:00 AM   #12
Rewards Points: 109
Thanks for the clarification... When I lookup tray ceiling I see a recessed part of ceiling but not via an 45 degree angel is.. More like a recessed box..
Old 09-10-2011, 10:49 AM   #13
KemoSabe
loneframer's Avatar
We refer to them as stepped, or recessed ceilings. possibly regional terminology
Old 09-10-2011, 11:10 AM   #14
Rewards Points: 109
Yea that's what I am finding.. I still have yet to a see a pic like mine on google.. But it seems crown molding on my ceilings are pointless now anyway
Old 09-10-2011, 07:24 PM   #15
KemoSabe
loneframer's Avatar
The architects in this area refer to your ceiling as a tray.
If the angled portion was greater than the flattened area, it would be referred to as a vaulted ceiling.
If the angle went to the structural ridge beam, it would be considered a full cathedral ceiling.
Then, you have your barrel vault into full tray
Crown molding-020.jpg   Crown molding-015.jpg   Crown molding-043.jpg   Crown molding-047.jpg
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
making own crown molding marin001 Carpentry 7 03-29-2010 12:08 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
